Hello, looks great! I could never even connect mine to wifi from the grohe app. Anybody else had troubles?
Does this integration work without internet (Grohe cloud servers), is it fully local?
@Schilli ping ^^
Hey, sorry for the late reply.
No the integration is communicating with the Grohe Servers as there are - at least what I know - no possiblities to directly communicate with the device unfortunatelly ![]()
Hey ![]()
can you just create a issue on the Github page for the project with a debug log so we can look into that.
./schilli
Hey @Raley ![]()
thanks for getting in contact with Grohe and sharing the information you got from them. Itās good to know that the servers keep active for the foreseeable future ![]()
To be honest I havenāt had any issues with the Sense Guard and wi-fi connections on my side, but itās in a separate wi-fi which only has a 2.4GHz network. I did this mainly to separate all the IoT devices. Also I had some problems with other devices when they had been connected to a mixed network.
Hi, Iām having a problem. Iām seeing two Grohe Sense sensors displayed, even though I only have one. One is online, the other offline.
Iāve already tried deleting the offline one, but it reappears after every Home Assistant restart.
Iāve also deleted the entire integration and reinstalled it after a Home Assistant reboot. Unfortunately, the same thing happens; the offline Grohe Sense sensor is immediately back.
Furthermore, I have a question: the āsensor.grohe_sense_water_consumptionā sensor tracks daily water consumption, correct?
Iām using the sensor for the energy monitoring feature integrated into Home Assistant.
Iāve simply deactivated the secound Grohe Sense sensors for now.
Thatās all for now.
Thanks.
Hi @n02m4n ![]()
Iām also using the sensor.senseguard_water_consumption for my energy dashboard as it is - as you said - the one for the daily water consumption.
For the Sense Guard which is always reappearing after a reboot even though you deleted it from the integration. Can you please check in the Grohe app if it is still shown there, as after a reboot all the devices - which are available from Grohe - are retrieved and added accordingly. So if it is still available there, it will be added again. Maybe you can give that a try.
./schilli
Thank you for your reply.
The Grohe app shows four devices: one Grohe Sense Guard and three Grohe Sense devices.
But no other Grohe Sense Guard.
Thatās why I asked.
Hey,
can you check within the Developer Tools -> Actions -> Get Dashboard Data how many appliances are returned.
The path should be locations[].rooms[].appliances[]. Can you check if the one Sence Guard is returned there somewhere.
./schilli
Yes, itās there. Two appliances.
- appliance_id: df9eee56-5209-4e0e-bc62-b1e1b9f4196c
installation_date: "2022-12-20T13:44:59.000+01:00"
serial_number: "no"
type: 103
version: ""
tdt: "0"
timezone: 0
role: owner
registration_complete: false
calculate_average_since: "2022-12-20T12:44:59.000Z"
snooze_status: NON_EXISTENT
data_latest:
measurement:
flowrate: 5.7
pressure: 3.3
temperature_guard: 13.5
timestamp: "2023-01-31T08:27:56.000+01:00"
withdrawals:
starttime: "2023-01-31T08:24:41.000+01:00"
stoptime: "2023-01-31T08:24:45.000+01:00"
waterconsumption: 0.4
maxflowrate: 8.1
average_daily_consumption: -1
average_monthly_consumption: -1
daily_consumption: 0
daily_cost: 0
command:
temp_user_unlock_on: false
reason_for_change: 0
pressure_measurement_running: false
buzzer_on: false
buzzer_sound_profile: 2
valve_open: true
measure_now: false
status:
- type: update_available
value: 0
- type: connection
value: 0
- type: wifi_quality
value: -1
notifications: []
installer:
email: ""
phone: ""
Grohe might still have it in the cloud.
I would only consider devices where āregistration_completeā is true.
That would certainly solve it easily.
Hey,
thanks for the info. Once back home Iām gonna add the registration_complete to the integration. Will let you know once there is a new release.
./schilli
Hey @n02m4n,
Iāve just released version 0.1.9. Maybe you can give it a try as it should solve youāre problem with the one sense guard being setup which is not fully registered.
./schilli
