Hi all,
I’m interested in having Grok Bot handle some work for me and it requires HA access. Has anyone figured out a way to do this yet? Perhaps via Cursor?Thanks.
-Scott
Hi all,
-Scott
Grok bot should support MCP I believe. (I don’t use grok but I’m almost 100% sure this is true - and if it’s not well… That’s thier problem every other agent platform does at this point)
Setup the HA MCP SERVER integration (server - not client, client allows an HA Assist agent to reach out using MCP, server allows a ln agent outside HA to reach in…) in HA (its a core integration) and then point your grok bot at it.
There are also custom MCP server integrations available for HA.
All standard cautions (make sure you have backups appropriate fences and security) before allowing any agent access through MCP or any other connection.
just use GitHub - homeassistant-ai/ha-mcp: The Unofficial and Awesome Home Assistant MCP Server · GitHub and it will give u an url and give it to grok bot
