I came across something potentially very useful in the Service Developer Tool today. When I typed group.set in the Service field, add_entities appeared as a possible parameter for that service!
My questions are:
Is add_entities implemented?
Is there also a delete_entities method?
If not can I use add_entities to replace the contents of a group?
The possibilities were swirling in my mind. I recently simplified @CCOSTAN’s speech code somewhat by creating a constantly updated list of turned on lights. I have found this list very useful elsewhere such as dimming lights every half hour in the evening… but only the lights that are already on.
Right now I store this list in a template sensor sensor.lights_on. It occurs to me that this list would be a good candidate to be converted to a group instead. Unfortunately I has been unable to get add_entities to change a test group I created.
Looking at the code it does look like add_entities is indeed implemented. Note that it is mutually exclusive with entities. (I.e., you can use one or the other but not both in the same service call.) add_entities will add the entity or entities listed to the group, whereas entities will replace the current list of entities in the group with those specified in the service call.
No, there is no delete_entities option currently.
No, as I described above, you would use entities to replace the contents of the group.
I might also add that this service can be used to dynamically create a group, too. I.e., if the group you specify does not exist, it will be created. In this case add_entities and entities effectively do the same thing. So you don’t necessarily need to define the group in your static configuration.
I’m a fan of that code too. I love tinkering with your code. It has been such an amazing starting point for me to explore. Thank you so much for sharing it.
I split the “action” portion of that code into a script, which I pass the trigger entity_id to. But I also added an automation to run every half hour to dim the lights that are already turned on as the night goes on. It serves double duty perfectly.
I like it… I experimented with Auto Dimming lights that were on already but reverted it since it was overriding manual adjustments… Although now with the lack of ALEXA dimming, we do MUCH less manual dimming. Might have to revisit this.
If you are looking for an example of dynamically creating a group as well as managing the group members, the code below may be of help. I ended up using entities instead of add_entities because it was a better fit for my use case.
@CCOSTAN: My family really seems to mostly appreciate the auto dimming. On the rare occasion when we need full brightness late at night we can just ask Alexa to set the light to 100.
@NotoriousBDG: Thank you! I recently added your battery monitor, it has been very helpful to keep track of all of my Xiaomi sensors, and to know when my Raincloud watering system is offline (so I can make sure it gets back online before my wife’s plants die).
I will pin this browser tab to look at when my Kitchen Remodel slows down. Thank you so much! It seems like creating a group would be the context appropriate way to create this list of “ON” devices. I look forward to revisiting my code soon.
I came across this old message, and I have been experimenting with more and more advanced code lately so I wanted to give this another shot. I took my code that updates custom variable, and swapped in a group.set instead. It works perfectly!
lights_on_update:
sequence:
# service: variable.set_variable
# data:
# variable: lights_on
# value_template: >
- service: group.set
data_template:
object_id: "lights_on"
entities: >-
{% macro get_lights_on() -%}
{%- for group in states.light|groupby('state') -%}
{%- for entity in group.list -%}
{%- if entity.state == 'on'
and entity.entity_id != 'light.dummy'
and entity.entity_id != 'light.garage_entry_light'
and entity.entity_id != 'light.hue'
and entity.entity_id != 'light.play_room'
and entity.entity_id != 'light.kitchen_undercabinet'
and entity.entity_id != 'light.porch_light'
and entity.entity_id != 'light.shoe_closet_light'
and not ('gateway_light' in entity.entity_id)
and not ('hub' in entity.entity_id)
and not (entity.entity_id).endswith('_led')
and not (entity.entity_id).endswith('nightlight')
and not (entity.entity_id).startswith('light.lamplinc') -%}
{{ entity.entity_id }}{{ ' ' }}
{%- endif -%}
{%- endfor -%}
{%- endfor -%}
{%- endmacro %}
{{ get_lights_on()|trim|replace(' ', ',') }}
Now I will have to consider if I want to use a group instead of a variable. It would be nice to be able to turn off only the on lights when I say Goodnight I suppose.
