Just like in other components, it should exist an autogenerated group for the person component, to make it easier to track of anybody is home.
I have to assume this is coming down the pipe. I hope, at least.
I’m curious if there is another way to highlight this feature request since it should be straight a forward solution.
I’d be interested in this feature as well. In the meantime, I’ve set up a binary sensor that does the same job for my purposes. Just replace “sensor.solar_elevation” with another entity that updates regularly in your instance - in my instance, I’ve got that one set up to update every 15 seconds or so, which is fast enough for my purposes.
binary_sensor:
anybody_home:
friendly_name: 'Anybody Home'
device_class: presence
entity_id:
- sensor.solar_elevation
value_template: >
{% set ns = namespace(found=false) %}
{% for state in states.person %}
{% if state.state == 'home' %}
{% set ns.found = true %}
{% endif %}
{% endfor %}
{{ns.found}}
Would be nice if this could be integrated as a group helper in the UI, instead of using yaml.
