Group Helper for Sirens
Missing from the Group Helper GUI is the ability to group sirens. Sirens are often all enabled at once to deter burglars etc. I have about 10 cameras that expose a siren that I would like to group into a Siren group to fire on a security breach.
I need that too. Also, I have a tuya siren that isn’t listed in HA as a Siren. Thanks.
Hello all,
this would be also a needed feature for me.
Indeed, by principle, the group integration should allow to address any prefix integration
siren is one of them, there could be other like “person”,
and to be updated if other types are created in the future.
I would this too! I would like to use a siren group to fire all smokedetectors of one of them is triggered!
Bump - Requesting this feature as well.
Makes quite obvious sense. Voted…
Any news on this topic?
Is there a way to group sirens even if in yaml?
I am too in need to have a Siren Helper Group where I can turn On/Off all the sirens I have throughout my house. I used them with something I rigged in HA as an alarm system. Quite annoying to have to add many actions (one per siren) in the automation entries.
Grouping sirens and converting switches to sirens and sirens to switches using helpers would be wonderful.
What kind of sirens are we talking about? My Zigbee siren has a “Show as” field in the configuration, so you can make it a switch and add it to a group.
Haven’t actually tried this, mind you. I’ve only got one. :laughing:
He’s talking about the siren entity type, not switch entity type
BUMP
This is needed, very annoying not to have it.
I would like to request this feature as well, makes sense to have for security systems, alarms, etc.
I would also like to be able to create a siren group in order to make an alarm system. My Tapo hub i’m unable to change into a switch group.
Thank you hope this can be added
Bump same seems like very useful thing that shouldn’t be too hard to implement.
Tons of reolink cameras with built in sirens id like to group and trigger from alarmo
Bump, I also need this
Another bumb, that would be great to avoid to change lot of automations and integration when adding a new siren to a home.
another bump please add this new feature I need it to disable all my siren one time in a button thanks
I have tried, when you create a template switch and then show as siren, I asks you if you want a siren entity type. If so, it creates a new one called siren.whatever. I didn’t expect that one. :slight_smile: I guess it refers to the template for whatever action it needs to do.
