Hi, I’m new to HA, and trying to configure light group. With group helper I created a group consisting from 4 zigbee lamps
It works, but very bad
Almost every switch does not turn on or turn off 1-2 lamps, and after that HA and z2m freezes for a minute
If you turn on the lamps individually, its work perfect, but switching 4 lamps at same time breaks system
I’m temporarily using a script that turns on the lamps in turn with a delay of 0.3 s and then it works more or less
Do you have any ideas on how to achieve normal work?
System: Raspberry pi 5 with Home assistant OS, sonoff zigbee 3.0 dongle E flashed with EZSP v13 7.4.3.0
