I want to group multiple remotes so that i can control one automation with any of the remotes in the group. Neither ZigBee Groups nor HomeAssistant groups seem to work here.
The remotes themselves are zigbee devices (OSRAM ledvance switch mini) and they give out events like “button 1 pressed”.
tom_l
July 4, 2023, 7:40pm
2
You should be able to do this with a single event trigger as they support templates. Can you give example events from two of the remotes?
You can record the events in Developer Tools → Events → Listen to events.
This would be an example for the off button:
event_type: zha_event
device_ieee: 00:0d:6f:00:14:17:b1:a0
unique_id: 00:0d:6f:00:14:17:b1:a0:2:0x0006
device_id: 246238ea127707d4d02616a09df36a26
endpoint_id: 2
cluster_id: 6
command: "off"
args: []
params: {}
origin: LOCAL
time_fired: "2023-07-04T20:04:33.005935+00:00"
context:
parent_id: null
user_id: null
Same button, different device:
device_ieee: 00:0d:6f:00:14:17:d7:1e
unique_id: 00:0d:6f:00:14:17:d7:1e:2:0x0006
device_id: 4c8f95df45c9169200bcd160166067a5
endpoint_id: 2
cluster_id: 6
command: "off"
args: []
params: {}
origin: LOCAL
time_fired: "2023-07-04T20:08:04.334613+00:00"
context:
parent_id: null
user_id: null
This is what the logbook shows:
emily_sm_1 Remote Button Short Press - Button 3 event was fired
22:04:33 - 2 minutes ago
emily_sm_0 Remote Button Short Press - Button 3 event was fired
tom_l
July 4, 2023, 8:56pm
4
This should trigger for the off button on any of the remotes:
automation:
- platform: event
event_data:
endpoint_id: 2
cluster_id: 6
command: "off"
Thank you, what if i want only specific devices? For example only the two mentioned above. Is there something like:
automation:
- platform: event
event_data:
endpoint_id: 2
cluster_id: 6
command: "off"
device_id:
- 246238ea127707d4d02616a09df36a26
- 4c8f95df45c9169200bcd160166067a5
tom_l
July 5, 2023, 8:08am
6
Yes I think that should work. Though your indentation is a bit off. Should be:
automation:
- platform: event
event_data:
endpoint_id: 2
cluster_id: 6
command: "off"
device_id:
The device id is part of the event data.
I only got it to work with one event id:
automation:
- platform: event
event_data:
command: "off"
In contrast, the following doesn’t work:
automation:
- platform: event
event_data:
command: "off"
device_id:
And neither does it work when a second id is added. Nor does it work with device_ieee
or unique_id
tom_l
July 5, 2023, 8:44am
8
Are you doing this with the automation editor or YAML?
If I recall correctly, the editor has issues with lists.
Try it like this:
automation:
- platform: event
event_data:
endpoint_id: 2
cluster_id: 6
command: "off"
- platform: event
event_data:
endpoint_id: 2
cluster_id: 6
command: "off"
I’m editing this in YAML, but this seems to be a general limitation. Thanks to this conversation i was able to search more accurately and found that others have also run into this already. The new code you sent does it in multiple triggers which i tried to get away from, but it doesn’t seem to work that easily. Thank you for your time.
tom_l
July 5, 2023, 9:27am
10
One more try:
automation:
- platform: event
event_data:
endpoint_id: 2
cluster_id: 6
command: "off"
condition:
- condition: template
value_template: >
{{ trigger.event.data.device_id in [
'246238ea127707d4d02616a09df36a26',
'4c8f95df45c9169200bcd160166067a5'] }}
- service: etc...
