Group not showing in Echo
I have created few groups in groups.yaml, but these don’t show in Amazon Echo.
Any way to force Amazon Echo to see these groups?
You’re updating them in the Alexa “Manage Entities” section, right?
I just go login on alexa.amazon.com , and I click discover to see new entities.
In the Home Assistant Cloud section in HA, go here first.
Nevermind, I just figured it out.
I had configured long time ago in cloud.yaml a filter with only 1 group exposed, this blocked me from adding more groups.
With your previous comment it prompted me to the solution thanks :slight_smile:
Actually, even if I removed completely the file cloud.yaml, it’s still telling me : Editing which entities are exposed via this UI is disabled because you have configured entity filters in configuration.yaml.
I’ve not setup filters in the yaml file, so I can’t help there.
I would suggest restarting HA if you removed the cloud file. It may work then in the UI.
