Group notification does not work
hello all
i must be dpoing something wrong, but i want to send notify in automation action to gorup notifer
i have this notifer for my phone mobile app
mobile_app_mi_10
and this automation action works fine:
  message: Some message1
action: notify.mobile_app_mi_10
i defined in configuration.yaml the following group
notify:
  - name: shai_kedem2
    platform: group
    services:
      - service: mobile_app_mi_10
when i try to send notification to that group, nothing happens
action: notify.send_message
metadata: {}
  message: Some group message
  entity_id: notify.shai_kedem2
in HA logs did not find anything or error related to that
i also tried to define it via helper UI but same result
any idea?
The notify.send_message action is the issue… use notify.shai_kedem2 as your action:
action: notify.shai_kedem2
metadata: {}
The notify entities that will be the targets of the notify.send_message service are still being phased in…
developers.home-assistant.io – 10 Apr 24
actually i solved it myself, i took wrong example from other posts
this one works
metadata: {}
  message: test group message
i still didnt manage to define the group via the helper UI create notify group
i only managed to do it via definition in config yaml
That is because the Notify Group Helper is meant for use with notify entities… as mentioned above those are still being rolled out. Currently, notify entities are only available from notification integrations, like File, that only do plain messages without titles or other data. The vast majority of notification integrations do not create notify entities yet, so they can’t be used in a Notify Group Helper.
