I have two dimmers controlling lights in a Group of lights, no travel wire.
Operating on the group works fine from HA applications. However, it falls apart (group members act independently) when physical buttons are pressed on each dimmer.
In search results, I see there are some intricate sync solutions, but groups are also suggested. Are the groups good only for having centralised control from Home Assistant, or can they truly keep lights in sync? Am I missing something in the config for the true sync?
My question, though, is if there is a straight setting for a Group of lights ot keep them synced without such custom code. Looking at your effort I assume the answer is a “No”.
Which i believe is similar to my setup, i don’t have any physical connection between the dimmer and the light. That works pretty ok, until the light brightness state is operated from HA; it won’t update the dimmer state. And since the light(s) cannot be grouped with the dimmer, i need this solution
