Group order not correct when using packages
Started using packages to keep my config a bit more organised, but have noticed that the order of my groups are not being respected in the gui views.
Is there some way to force a particular group order?
At present I have groups set up like…
group:
view: yes
- entity_id: group 1
- entity_id: group 2
- entity_id: group 3
But in the GUI those entities are showing up as…
group 2
group 1
group 3
I would prefer them to show in the order they appear listed in the group
Try using group order in customize:
#  Group Order
 group.aeotec_smart_switch_1:
   order: "1"
 group.aeotec_smart_switch_2:
   order: "2"
 group.aeotec_smart_energy_switch:
   order: "3"
 group.outside:
   order: "11"
 group.livingroom:
   friendly_name: living room
   order: "12"
 group.hallway:
   order: "13"
 group.office:
   order: "14"
 group.bedroom:
   friendly_name: bedroom
   order: "15"
 group.diningroom:
   friendly_name: dining room
   order: "16"
 group.tearoom:
   friendly_name: tea room
   order: "17"
 group.upstairs:
   friendly_name: second floor
   order: "18"
 group.ecobee:
   order: "19"
 group.nest_protect_downstairs:
   friendly_name: Nest Protect Main Floor
   order: "20"
 group.nest_protect_upstairs:
   friendly_name: Nest Protect Second Floor
   order: "21"
Thanks,
I tried that, but I have also started using the new customize format so have to use…
homeassistant:
  customize:
    entity_id: group.1
    order: "1"
Received an error…
17-02-08 22:18:05 ERROR (Thread-3) [homeassistant.util.yaml] mapping values are not allowed here
  in "/config/includes/packages/plex.yaml"
Edit: removing the quotes has now fixed this!..
homeassistant:
  customize:
    entity_id: group.1
    order: 1
Many thanks for the help!
I’m not sure what I am doing wrong but I cannot get it to work at all. No matter where I put that it messes everything up.
Maybe try post up the code you are using to see if we help can troubleshoot it?
It’s all up to date on my git - https://github.com/Norien/Home-Assistant-Config
Had a quick scan but cannot find anywhere in those files where you reference group orders maybe give a specific example?
Also my experience of using packages i have found that having customisations in different files caused problems, so ended up with just one customize.yaml file for all my various customisations
Ok here is my view:
default_view:
view: yes
icon: mdi:home
entities:
  - group.livingroom
  - group.bedroom
  - group.findlays_room
  - group.office
  - group.backyard
  - group.laundry_room:
And inside this package is my laundry room which I have placed last in the group.
https://github.com/Norien/Home-Assistant-Config/blob/master/packages/laundry_room.yaml
However it shows up first on the views page. The order doesn’t even remotely match.
Unless i am missing something, you have not used group orders in those snippets of code as rpitera suggested…
homeassistant:
  customise:
    group.hallway:
      order: 13
    group.office:
      order: 14
    group.bedroom:
      order: 15
Have i misunderstood what you are asking?
Edit: So here’s my full working code…
Pages.yaml…
    group:
      default_view:
        view: true
        entities:
          - group.today
          - group.tomorrow
          - group.home
          - group.web
          - group.living_room_lights
          - group.outside
          - group.media_centre
Customise.yaml…
homeassistant:
  customize:
    group.today:
      order: 1
    group.tomorrow:
      order: 2
    group.home:
      order: 3
    group.living_room_lights:
      order: 4
    group.outside:
      order: 5
    group.media_centre:
      order: 6
    group.web:
      order: 7
I had to take it out as it would keep breaking my groups completely. I’m not sure what I’m doing wrong no matter where I put that it breaks. I can’t find any documentation regarding group ordering …
You may need to put all customisations into one yaml file, rather than having them scattered around the different packages.
I found i had issues until I created the single customise.yaml. i now don’t have customisations in any other file & it works fine for me
I don’t think it’s documented - I found out about it in the forums.
That’s how I have mine; I don’t use packages. I would think that at the least you’d have to have all the group orders in customize.yaml in it’s entirety.
Yes, i think packages are good for combining certain bits, but having customisations across lots of packages means you are more likely to create potentially conflicting customisations - e.g. if you added group order: 2 to two separate packages then that would be conflicting, but because you have customisations spread around you’d never know where the conflict was happening!
