Grouping rooms is possible as far as I have tested in v.0.11.0, but the general home switch cannot be used to set all switches ON/OFF, it just modify when other switches are changed individually or room switches:
switch.Rel204[/code]
Is this the right behaviour or it is a bug? Thank you
Update: if a switch is included at Home level, it can be managed by the general Home switch only if all the rooms are OFF:
r2
r1:
view: yes
entities:
- switch.Sw1
- switch.Sw2
r2:
- switch.Sw3
- switch.Sw4[/code]
At Home level I see the groups R2 and Switch and R1 as a tab. While R2 has a general switch, the R1 doesn’t have one general switch.
I was also trying to add some sensors, but the sensors are not shown at all in the promoted tabs. Do you have any advice here?
