I’m changing my config with a lot of new lights and a smart thermostat. But I’m getting stuck with HASSIO by making groups and tabs (views).
I can’t figure it out. Hope there is someone who can help me.
groups.yaml:
#Groups
badkamer:
entities:
- climate.badkamer
- sensor.badkamer_temprature
- sensor.badkamer_heating
slaapkamer:
entities:
- light.slaapkamer_1
- light.slaapkamer_2
- light.slaapkamer
logeerkamer:
entities:
- light.logeerkamer
- light.logeerkamer_1
- light.logeerkamer_2
- light.logeerkamer_3
woonkamer:
entities:
- climate.woonkamer
mediaplayers:
entities:
- media_player.spotify
- media_player.woonkamer
- media_player.samsung_6_series_40_ue40mu6470
#Tabs
default_view:
view: yes
entities:
- group.woonkamer
- group.mediaplayers
mediaview:
view: yes
entities:
SSH-error:
ERROR
panic: interface conversion: interface is nil, not string
goroutine 1 [running]:
panic(0x2c5f60, 0x1070b640)
/home/travis/.gimme/versions/go1.7.6.linux.amd64/src/runtime/panic.go:500 +0x33c
github.com/home-assistant/hassio-cli/command/helpers.DisplayOutput(0x107b6200, 0x24, 0x200, 0x0)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:118 +0x3c8
github.com/home-assistant/hassio-cli/command/helpers.ExecCommand(0x2f5e63, 0xd, 0x7ec47e60, 0x7, 0x0, 0x0, 0x76000, 0x0, 0x0, 0x0, ...)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/helpers/common.go:155 +0x308
github.com/home-assistant/hassio-cli/command.CmdHomeassistant(0x10778420)
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/command/homeassistant.go:48 +0x540
github.com/urfave/cli.HandleAction(0x2ae6d8, 0x323754, 0x10778420, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:503 +0xf0
github.com/urfave/cli.Command.Run(0x2f5e63, 0xd, 0x0, 0x0, 0x409d10, 0x1, 0x1, 0x300cfa, 0x2f, 0x0, ...)
/home/travis/gopath/src/github.com/urfave/cli/command.go:165 +0x6b8
github.com/urfave/cli.(*App).Run(0x107648c0, 0x1070a160, 0x3, 0x4, 0x0, 0x0)
/home/travis/gopath/src/github.com/urfave/cli/app.go:259 +0x8b0
main.main()
/home/travis/gopath/src/github.com/home-assistant/hassio-cli/main.go:22 +0x108
HA error log:
Error decoding json invalid character 'R' looking for beginning of value: RuntimeError: Event loop is closed
2018-04-04 22:00:18 WARNING (Dummy-9) [root] Observation deleted without explicit cancellation
Exception ignored in: <bound method _BaseClientObservation.__del__ of <aiocoap.protocol.BlockwiseClientObservation object at 0x70ba8510>>
File "/usr/lib/python3.6/site-packages/aiocoap/protocol.py", line 1674, in __del__
self._unregister()
File "/usr/lib/python3.6/site-packages/aiocoap/protocol.py", line 1682, in _unregister
self._registry_data()
File "uvloop/loop.pyx", line 1167, in uvloop.loop.Loop.call_soon
File "uvloop/loop.pyx", line 567, in uvloop.loop.Loop._call_soon
File "uvloop/loop.pyx", line 571, in uvloop.loop.Loop._call_soon_handle
File "uvloop/loop.pyx", line 599, in uvloop.loop.Loop._check_closed
Exception ignored in: <bound method _BaseClientObservation.__del__ of <aiocoap.protocol.BlockwiseClientObservation object at 0x70ba87f0>>
self._unregister()
2018-04-04 22:00:18 ERROR (Dummy-9) [homeassistant.core] Error doing job: Task was destroyed but it is pending!
2018-04-04 22:00:30 ERROR (SyncWorker_0) [homeassistant.util.yaml] while scanning for the next token
found character '\t' that cannot start any token
in "/config/groups.yaml", line 4, column 1
2018-04-04 22:00:30 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while scanning for the next token
2018-04-04 22:15:01 ERROR (SyncWorker_0) [homeassistant.util.yaml] while scanning for the next token
2018-04-04 22:15:01 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: while scanning for the next token
