Hey folks. First post here. I am scratching my head and I cannot get this to work.
I have several Soil moisture sensors which are monitoring moisture.
I groupped them into one sensor group.
I spend already few hours prototyping with many LLMs but I can’t get automation to work.
Each sensor has three entities:
- sensor.bedroom_soil_sensor_1_battery
- sensor.bedroom_soil_sensor_1_soil_moisture
- sensor.bedroom_soil_sensor_1_temperature
I care about sensor.bedroom_soil_sensor_1_soil_moisture
This is how the sensor looks.
Following code doesn’t work
alias: Low Soil Moisture Notification
description: "Notify when soil moisture falls below 30%"
- platform: time_pattern
hours: "/6"
- platform: state
entity_id: sensor.soil_moisture_group
condition:
- condition: template
value_template: >-
{% set low_sensors = namespace(count=0) %}
{% set sensors = states.sensor | selectattr('entity_id', 'search', 'soil_sensor') | selectattr('entity_id', 'search', 'soil_moisture') | list %}
{% for sensor in sensors %}
{% if sensor.state not in ['unavailable', 'unknown'] and sensor.state | float < 30 %}
{% set low_sensors.count = low_sensors.count + 1 %}
{% endif %}
{% endfor %}
{{ low_sensors.count > 0 }}
# Mobile app notification (persistent)
- service: notify.notify
message: >-
{% set low_moisture_plants = [] %}
{% set low_moisture_plants = low_moisture_plants + [sensor.attributes.friendly_name] %}
{% endif %}
{% endfor %}
Soil moisture is low! Plants needing water: {{ low_moisture_plants | join(', ') }}
persistent: true
tag: soil_moisture_alert
priority: high
ttl: 0
actions:
- action: PLANTS_WATERED
title: Mark as Watered
# Persistent notification in Home Assistant UI
- service: persistent_notification.create
title: "Low Soil Moisture Alert"
message: >-
{% endif %}
{% endfor %}
notification_id: "low_soil_moisture"
mode: single
My automation should notify me if the soil moisture is below decimal defined %. How can I make this thing work?
best regards
Wojciech
