i am using several motion and state sensors for my alarm system which i implemented completely in node-red.
I want to do a rewrite and thought it would be a good idea to create a group of sensors in home assistant and just listen to state_changed of that group in node-red.
The problem is, that i do not want to trigger the alarm immediatley when the first sensor is triggered. Currently i am waiting for 3 sensors triggering in 120seconds before triggering the alarm (that part i want to leave in node-red). The group just outputs its “global” state change but not every single sensor change within the group.
In short: I want to have grouped items in home assistant which send every state change without having the need to filter them manually in node red.
any ideas appreciated
Because we are talking about 70 devices
I could use a few nodes with some kind of regex but that is not my intention.
Then i better keep it as it is right now.
Oh I see so you are saying if one entity triggers the group and the group hasn’t had a chance to reset it won’t pick up another trigger because the original already set it to on?
