I’m using a the SRM integration to track who’s home. The great thing about the SRM integration is that it also tracks my guest network (ip’s starting with 192.168.2, that are outside my home network, and not reachable by home assistant).
I create one person in home assistant called “guest” so i can keep track if a guest is present (a parent babysitting etc).
So ideally i would like to group all devices starting with 192.168.2, into one device, or add them all automatically to the person called guest.
Thanks! Thats a great idea! The devices are added automatically every time some one is entering the guest network and since the ip range is different ill try this template sensor for now:
