Grouping REST sensor entities?
I have a solar hot water system which has a data-collection device, and I’ve figured out that that device has a rest API. Cool. I’ve set this up and it all works:
rest:
  - resource: http://192.168.1.80/dlx/download/live
    scan_interval: 60
      - name: "Solar Hot Water Collector Top"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[0].raw_value }}"
        device_class: temperature
        state_class: measurement
        unit_of_measurement: "°C"
      - name: "Solar Hot Water Tank Bottom"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[1].raw_value }}"
      - name: "Solar Hot Water Tank Top"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[2].raw_value }}"
      - name: "Solar Hot Water Unknown Temperature Sensur"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[3].raw_value }}"
      - name: "Solar Hot Water Pump Speed"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[4].raw_value }}"
        #icon: "mdi:pump"
        unit_of_measurement: "%"
      - name: "Solar Hot Water Operating Hours"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[6].raw_value }}"
        state_class: total_increasing
        #icon: "mdi:clipboard-text-clock-outline"
        unit_of_measurement: "h"
      - name: "Solar Hot Water Heat Quantity"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[17].raw_value }}"
        #icon: "mdi:solar-power"
        unit_of_measurement: "Wh"
    binary_sensor:
      - name: "Solar Hot Water Sensor 1 Defective"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[12].raw_value }}"
        device_class: problem
      - name: "Solar Hot Water Sensor 2 Defective"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[13].raw_value }}"
      - name: "Solar Hot Water Sensor 3 Defective"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[14].raw_value }}"
      - name: "Solar Hot Water Sensor 4 Defective"
        value_template: "{{ value_json.headersets[0].packets[0].field_values[15].raw_value }}"
… took me a little while to figure out that value_json starts at the root, making json_attributes_path / json_attributes not very useful. (Unfortunately, the returned JSON is… kind of disorganized. It’s really meant to feed a website template, not to get useful values from. But it works!)
However, I would like to group all of these things together into a “Solar Hot Water” device. Is there a way to do that, without creating a complete integration?
You could have one of them as the state and the rest as attributes.
Is that what you are looking for?
Maybe! There’s not really a single overall value that is the state — maybe “is the pump going?” or “temperature at top of tank”. But I guess that could give me what I’m looking for. Do you have an example of how to do that with Rest entities?
Let me update my answer, having looked around a bit. I think really for this case, I do want a device with different entities (although maybe also some entities with different attributes). But, I can see cases where I’d want to have that for sure. How can I create attributes instead of independent entities?
I think you can do something like this:
rest:
    scan_interval: 60
        json_attributes:
          - headersets[0].packets[0].field_values[1].raw_value
          - headersets[0].packets[0].field_values[2].raw_value
and so on.
But I’m not completely sure.
Ahhh. That wasn’t working for me… but now it makes sense. This is why some of the examples have “Okay” as the value_template. I’ll try that and see if it works!
I believe the issue is that the fact that the attributes is directly to values, it probably needs to be key value pair.
I think this could work, but it’s not pretty.
        json_attributes:
