ih8gates
(Scott Reston)
January 29, 2017, 6:38pm
2
Use preformatted text when posting YAML
Tips for new HASS/forum users. Help me out - what did I miss?
Posting your configuration
When you post your configuration, we need to see that you’ve got the spacing/indentation right. Use the “preformatted text”
[image]
YAML tips
YAML can be a harsh mistress. Spaces matter, tabs can break things. Here’s a post with some tips for editing YAML with Notepad++
What Home Assistant install method should I use?
If you’re pretty technical, use whatever works for you. Docker, NAS, All-in-one, Has…
When you add a sensor to a view without adding it to a group, it’ll display at the top. So add the sensors to a group, add that group to a view (group with view:yes). Some helpful info here:
