I’ve recently migrated to ZHA from Zigbee2MQTT because I had trouble keeping my config stable (bulbs would fall out of contact, then need to be manually re-added to groups etc.)
I have all IKEA devices, mostly GU10 spots, and some E27 and E14 bulbs plus a few remote controls.
The bulbs themselves seem to work fine, and a fair bit faster than they did in Z2M, but groups seem not to work whatsoever. I’ve set up 4 groups with 3-6 bulbs in each, but they do not respond to any commands from the UI, or from zha.issue_zigbee_group_command with the following settings:
group: 0x0004
cluster_id: 0x0006
command: 0x0001
Are there any extra steps I could take to fix this? I see there is a fairly advanced bindings menu on the bulb entities themselves - does this need to be used?
I did, however it tends to make some lights not respond to the first command, and also makes my Ikea lamps hang up sometimes requiring a power cycle to get them back to working:/
Ah, awesome, thank you for that pointer, I was looking in the wrong repository - that means there’s nothing wrong with my setup at least, so I’ll give it a few and see if the issue gets closed:)
