I am trying to add DarkSky sensor and show them as a Group. I have followed the simple examples. My understanding is that after making changes in configuration.yaml and groups.yaml, the created groups will automatically show up on Home page. However, in my case no such thing happens. Anyone who can help, please. Here are my files.
in addition to what @123 said above you might also need to add them to your lovelace configuration in different ways depending on how you have it being controlled (auto, yaml or GUI).
Ok. So I get from here is that I need to manually add the card. So I clicked Entities and then selected group.darksky_group as the entity. Now I think group.darksky_group is having data issue as I get unknown in the data. Guess that will be a new question that why it gives unknown.
I guess I am doing something wrong here. May be it is not Entities that I need to select from the card selection for this to work? The options are below. What I want is to list all weather conditions listed as a group.
If a group contained ten lights, the group’s state is:
on if at least one of the ten light is on
off if all ten lights are off
Each group member has something in common, their state is either on or off.
Now compare that to your darksky group. Its members are temperature, humidity, pressure, cloud coverage, etc. Do they have common values for their state? No, each member has a unique numeric value so there’s no way to summarize the entire group’s state as simply being on or off or even 21 or something like that. So the group’s state is unknown.
You’re conflating the word “list” with Home Assistant’s term group. The term group has special meaning in Home Assistant and it’s not to display all the group’s members in the user-interface. A group is a collection of entities and only the group’s state is reported (in the States page and in the UI).
To display several entities as a list, use the entities card and specify each entity.
