I’m new with Home Assistant, but unfortunately I have a lot of trouble in creating groups. I woul like to organize the dashboards per room. So let’s say I have one room, the bedroom. In the bedroom I have some Lifx bulbs which are named as group.all_lights entity. The groups.yaml file looks like this:
General Errors:
- Setup failed for group: Invalid config.
- Unable to setup dependencies of automation. Setup failed for dependencies: group
- Setup failed for automation: Could not setup all dependencies.
- Unable to setup dependencies of light. Setup failed for dependencies: group
- Setup failed for light: Could not setup all dependencies.
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: **
longitude: **
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 656
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Zurich
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Uncomment this to add a password (recommended!)
# api_password: PASSWORD
# Uncomment this if you are using SSL or running in Docker etc
# base_url: example.duckdns.org:8123
api_password: **
ssl_certificate: **
ssl_key: **
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
#sun:
# Weather Prediction
- platform: mqtt
state_topic: "myhome/dariobedroom/temperature"
name: 'Dario Bedroom Temperature'
unit_of_measurement: "°C"
- platform: mqtt
state_topic: "myhome/dariobedroom/humidity"
unit_of_measurement: "%"
# Text to speech
tts:
platform: google
group: !include groups.yaml
light:
- platform: lifx
mqtt:
broker: localhost
port: 1883
username: **
password: **
keepalive: 60
