@muppet3000 Did the ‘AC Couple’ inverter type get added into the growatt integration? I remember seeing you were working on it a while back, but I’ve just had a system installed and it doesn’t seem to be picking it up.
Note This isn’t the current server issue that requires changing to server-api.growatt.com as I’ve made the change in my core.config_entries and my other inverters are working fine.
Hi, think I’ve probably got the same one as you, as I get “AC Couple” back as well. I do get data, but it’s not much, there are 6 fields, but only 2 seem to have any data 1) current solar power and 2) lifetime solar power, but there seems to be more data in the user interface.
