Seems the issue arise due to change of URL by Growatt to https://openapi.growatt.com
Currently the integration offer selection of 3 URLs, however it would be great if end user also able to type custom URL should Growatt decided to change the URL again in the future.
I user modified the const.py code to add https://server.growatt.com as I couldn’t login on any of the predefined servers. Adding a user modifable list of servers seems like a good idea.
HA newbie here. Can you explain how to do this please. I have an account at https://server.growatt.com but this does not come up in the choices in the Growatt config screen. How do I get to const.py code?
I’ve installed the Studio Code Server whose Explorer shows me that every custom component has a const.py file. Of course the one for the Growatt integration is not there because i can’t get past the screen where you choose a URL to log into…
… so…where can I find the files for integrations that have not been installed yet?
Thanks to Frank from Growatt support NL the integration works again. Decrepated URLS are replaced by new URLS. Just updated HA to the latest release and re-installed Growatt integration.
Was aan het rondkijken hoe ik het probleem van de integratie van Growatt in HA kon oplossen en zag jouw post. Nu heb ik HA uptodate, maar kan nog steeds niet inloggen. Kan jij nog wel inloggen? Bedankt.
Als je een account hebt aangemaakt op https://openapi.growatt.com en je kunt dus inloggen op dat platform dan kun je die gegevens gebruiken om op de HA app in te loggen.
Letop: log in met je gebruikersnaam, niet met je e-mail.
