I think there are different templates for different inverter models and MOD is not yet defined?
In grott (2.7) configuration I added for “inverter mapping” {“XXXXXXXXXX”:“mod”} for testing and nothing came back.
With {“XXXXXXXXXX”:“sph”} I got a now 87 entities for 2 devices.
Load Consumption Energy fields are showing up but actually strange values
Also Battery fields are now present
Without any entry I got 49 entities and also 2 devices.
But I am not sure if the mapping template of SPH is working well also for MOD inverters.
Where can I find the mapping templates, and maybe any hint how to reverse engineer them to get MOD integrated?
My mqtt output from grott does not have these, if I look at the grottconf.py, they only apply in special cases but I am not knowledgeable enough to define ‘which’.
I would raise a question with grott (the server part, not the fron-end you refer to above)
There are more forks, not sure which you used johanmeijer/grott: Growatt inverter monitor (github.com)
