Growatt integration - server / URL missing
i want to add a new integration for my Growatt. When I do this, I will get an error:
“Unknown error occurred” or “Ungültige Authentifizierung”
The URL´s did not work for me.
  • server-api.growatt
  • server-us.growatt
  • server.smten
When I log in via Browser to https://server.growatt.com/ it will work.
Maybe the right URL is missing. How can I change the URL?
Jens
I follow, it hasn’t worked for me too for two days.
More people with issues, I moved early 2023 to this being a local server muppet3000/homeassistant-grott: Home Assistant Integration for Grott - MQTT (github.com)
There is also some add-on I understand
Following, i have the same issue.
A different smarthome device/service I use also draws information from Growatt’s API; they emailed recently to say that Growatt has changed things on their side making it currently impossible to use the API. Hopefully this isn’t permanent - that would seriously suck.
Any known updates on this issue?
update
nevermind this is kown issue on github. Growatt Server URL has changed.
beta version of the intergration with the new URL is availible via HACS.
Hi and thanks for the solution.
Yesterday I installed the HAC integration and it worked well till this morning.
Now all the sensors are “unknown”.
do you know if something is changed again?
Ciao
Mario
Screenshot 2024-01-10 alle 15.42.47
