According to the ESP Home dashboard, it is offline, but the sensors are usually accessible
the ota update is difficult to install
the wireless logra rarely responds and becomes available
For some time now, the sensors have become increasingly unavailable
substitutions:
device_name: growatt-inverter
friendly_name: "Inverter"
# GAS Meter
pulse_pin: D6
pulse_rate: '100' # imp/m3
esphome:
esp8266:
board: d1_mini
# Enable Home Assistant API
api:
encryption:
key: "CRqV9zmrt6p9A6+p5spU5k/PsuRBjRUnwAfIZAJhhko="
ota:
password: "588a075af33faa652b9be6978286353c"
web_server:
port: 80
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Growatt-Modbus Fallback Hotspot"
password: "12345678"
captive_portal:
logger:
level: DEBUG
baud_rate: 0
time:
- platform: homeassistant
uart:
- id: mod_bus
baud_rate: 9600
tx_pin: GPIO1
rx_pin: GPIO3
modbus:
uart_id: mod_bus
modbus_controller:
- id: growatt
address: 0x1
modbus_id: modbus1
setup_priority: -10
text_sensor:
icon: mdi:eye
entity_category: diagnostic
update_interval: 5s
lambda: |-
if ((id(status).state) == 1) {
return {"Normal"};
} else if ((id(status).state) == 0) {
return {"Standby"};
} else if ((id(status).state) == 2) {
return {"Discharge"};
} else if ((id(status).state) == 3) {
return {"Fault"};
} else if ((id(status).state) == 4) {
return {"Flash"};
} else if ((id(status).state) == 5) {
return {"PV Charging"};
} else if ((id(status).state) == 6) {
return {"AC Charging"};
} else if ((id(status).state) == 7) {
return {"Combined Charging"};
} else if ((id(status).state) == 8) {
return {"Combined Charging & Bypass"};
} else if ((id(status).state) == 9) {
return {"PV Charging & Bypass"};
} else if ((id(status).state) == 10) {
return {"AC Charging & Bypass"};
} else if ((id(status).state) == 11) {
return {"Bypass"};
} else if (id(status).state == 12) {
return {"PV Charge and Discharge"};
} else {
return {"Unknown"};
- platform: wifi_signal
name: "Growatt WiFi Signal Sensor"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "Growatt WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "%"
- platform: modbus_controller
address: 0
register_type: "read"
internal: true
accuracy_decimals: 0
# PV1 Voltage
name: "${friendly_name} PV1 Voltage"
address: 3
unit_of_measurement: V
device_class: voltage
state_class: measurement
icon: mdi:sine-wave
value_type: U_WORD
accuracy_decimals: 1
filters:
- multiply: 0.1
# PV2 Voltage
name: "${friendly_name} PV2 Voltage"
address: 7
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
# PV1 Current
name: "${friendly_name} PV1 Current"
address: 7
unit_of_measurement: A
device_class: current
icon: mdi:current-ac
value_type: U_WORD
filters:
- multiply: 0.02
# PV2 Current
name: "${friendly_name} PV2 Current"
address: 8
value_type: U_WORD
filters:
- multiply: 0.02
# AC Freqency
name: "${friendly_name} AC Hz"
address: 37
unit_of_measurement: Hz
icon: mdi:chart-bell-curve
value_type: U_WORD
filters:
- multiply: 0.01
# Output Power
name: "${friendly_name} AC Output Power"
address: 35
unit_of_measurement: W
device_class: energy
icon: mdi:flash
value_type: U_DWORD
accuracy_decimals: 2
filters:
- multiply: 0.1
# AC 3 Fázis Power (L1, L2, L3)
name: "${friendly_name} L1 Power"
address: 40
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} L2 Power"
address: 44
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${friendly_name} L3 Power"
address: 48
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
# AC 3 Fázis Voltage (L1, L2, L3)
name: "${friendly_name} L1 Voltage"
address: 38
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} L2 Voltage"
address: 42
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} L3 Voltage"
address: 46
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
# AC 3 Fázis Current (L1, L2, L3)
name: "${friendly_name} L1 Current"
address: 39
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} L2 Current"
address: 43
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} L3 Current"
address: 47
value_type: U_WORD
filters:
- multiply: 0.1
# AC 3 Fázis Voltage (RS, ST, RT)
name: "${friendly_name} RS Voltage"
address: 50
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} ST Voltage"
address: 51
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} TR Voltage"
address: 52
icon: mdi:sine-wave
value_type: U_WORD
filters:
- multiply: 0.1
# Temp
name: "${friendly_name} Inverter Temperature"
address: 93
unit_of_measurement: °C
device_class: temperature
icon: mdi:thermometer
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} The inside IPM in inverter Temperature"
address: 94
value_type: U_WORD
filters:
- multiply: 0.1
name: "${friendly_name} Boost temperature"
address: 95
value_type: U_WORD
filters:
- multiply: 0.1
# KWh
- platform: total_daily_energy
name: "${friendly_name} AC Ouput Energy Today"
power_id: ac_output_power_high
unit_of_measurement: kWh
icon: mdi:counter
restore: true
filters:
- multiply: 0.001
# Pac3
name: "${friendly_name} Pac3 H"
address: 48
unit_of_measurement: VA
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
# Total/Today Energy
name: "${device_name} Energy Today"
address: 53
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
name: "${device_name} Energy Total"
address: 55
state_class: total_increasing
icon: mdi:flash
value_type: U_DWORD
filters:
- multiply: 0.1
# Gas meter
- platform: pulse_meter
pin:
number: ${pulse_pin}
mode: INPUT_PULLUP
on_value:
then:
- light.turn_on:
- delay: 0.5s
- light.turn_off:
internal_filter: 400ms
name: "Gas consumption"
filters:
- multiply: 0.06
unit_of_measurement: "m³/ min"
icon: 'mdi:fire'
total:
device_class: gas
unit_of_measurement: "m³"
filters:
- lambda: return x * (1.0 / ${pulse_rate});
# Outdoor Temp
- platform: dht
pin: D1
temperature:
name: "Outdoor Temperature GW"
humidity:
name: "Outdoor Humidity GW"
status_led:
pin: GPIO2
# Gas LED
light:
- platform: binary
internal: true
output: output_red
output:
- platform: gpio
pin:
number: D7
