Growatt Server fail to connect after reboot
I have most of the times that Home Assistant restart or reboot the growatt server intergration does not come online. And if I waant to restart it manualy it gifs a OK but nothing happens. Till.... it does (1 hour til 1 week) In the mobile app I have sometimes the same issue but not as often as home assistant. Try to get a token but that does not work neither. Can anyone assista me with this?
Growatt Server - Versie 1.0.4
Home assistant latest core and supervisor
Log:
Logger: homeassistant.components.sensor
Bron: helpers/entity_platform.py:455
Integratie: Sensor (documentatie, problemen)
Eerst voorgekomen: 04:43:47 (33 gebeurtenissen)
Laatst gelogd: 11:09:38
Error while setting up growatt_server_api platform for sensor: 'user'
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 455, in _async_setup_platform await asyncio.shield(awaitable) File "/config/custom_components/growatt_server_api/sensor.py", line 88, in async_setup_entry devices, plant_id = await hass.async_add_executor_job(get_device_list, api, config) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 86, in run result = ctx.run(self.task) File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 73, in run return fn(*args, **kwargs) File "/config/custom_components/growatt_server_api/sensor.py", line 51, in get_device_list user_id = login_response["user"]["id"] ~~~~~~~~~~~~~~^^^^^^^^ KeyError: 'user'
I have the same error. Any luck solving it?
Also seeing this in the logs
Device meter with type 3 not supported in Open API V1, skipping
No. Still nothing. It works again now after couple of times retrying. Growatt don't answer either
This is now resolved for me. Seems Growatt had issues with their API.
Nice to here. But I never got it running with API. And still can't. I use user and password.
I Still have failure by reboot. And takes me several times reloading the growatt add-on to connect (or not) Sometimes its the next day. Anyone who has the same?
For who is interested. I switch to this.
works great.
