Hi all, I’m having problems controlling my Growatt SPH + Battery system via both Home Assistant and Solar Assistant.
Can anyone tell me what the switch to the right of the Growatt SPH title is/does in the attached picture.
Should I have Backup EPS enabled as show in the picture? I don’t have any backup system and I’d hate to fry an engineer if there was a power outage (we do get the odd short one).
EPS stands for “Emergency Power Socket” as far as I know. Our SPH inverter has a red double-gang power socket wired to it, and if Backup EPS is enabled then this socket will be live, powered by the inverter, even in a power cut when the rest of the house loses power. It’s so that you can run an extension lead from the socket to power e.g. your fridge/freezer if there was an extended power cut, or a kettle etc.
The switch in your screenshot by the title, assuming that card is from your Overview dashboard, is an automatically created toggle that will turn on/off all the entities that are shown in that card (so probably not something you want to use in this case).
