I woul like to integrate my Growatt inverters without a cloud connection.
The Growatt inverters have a RS-485 connector (A and B) that I connected to an EW11 to “convert” the data to TCP-IP
I found some info on GitHub but… Without any “novice” explanation.
The EW11 can also do MQTT,
I do have Mosquito running (,for my Panasonic heat pump integration) and that works well.
But it has been pretty long since I have made the work.
Then install the solax modbus integration from the HACS library and use the following settings after installing the integration
Due to posting limitations for new users (one image per post) i wont post the first setup window in the solax setup page.
But type in the following:
-Your waveshare ip adress (in my case this was 192.168.11.111)
-TCP port: 502 (or same as was configured in de waveshare)
-select “Modbus TCP”
Then press send and in the following page set the settings as in the image below.
Very interesting, but how did you connect this to the invertor? I have an 8000TL3, so I assume it’s similar. I have a “big” rectangular shape “block” that (I assume) fit’s in the com connector from the invertor. Pin3/4 should be for modbus. Did you just connect those two wires in that “block”?
And, more important, do you have the ability to set values / write values to the invertor. Like reducing solar output or switch battery modes / charge times/power, etc. Do you have some screenshots of the HA entities?
I did exactly this. I don’t have Waveshare R485 but something from Aliexpress named USR-DR164. Connected to 3,4 and it works. I’m able to set some values too.
The TL3 series have a GREEN connector hidden behind a cover that says RS485. According to the manual the left (of the 3) connector should be “B” and the one to the right, “A”
I do have my more modern XH (4kW) working, but the 7000 TL3-S not yet.
Could be a baud rate setting, could be the address for the RS 485, could be the A/B are reversed.
Need time to find out, but with the 4000 XH it was pretty straight forward
Unfortunately, I can see the Serial number of the 7kW (TL3-S) but no data.
I know the setting is on GROWATT (in Solax)
I have tried (because I am using 2 inverters) to change the port from 502 - 503 (which should not make any difference as it’s on another IP address)
But no data seems to be sent.
Does the TL3-s need some sort of “start” to spit out the data?
Hi, what type of inverter do you have? I have GW SPH, but i am not able to get stable communication. Like somethink is putting asleep… May i ask you for help? Ican connect to GW SPH using other modbus tools on my PC, reading addresses etc, but SOLAX integration have problem to read the values…
I had a problem getting modbus going on a Growatt MTL via the RS485 port.
With the windows program "modbusmaster"and a modbus to USB converter I got a fault code 2.
After removing the wifi dongle and completely powering down and up the inverter and leaving the dongle out, modbus started working.
Then you can put the USB converter straight in HA and it works. (when you have your modbus correctly set up in HA). It is possible to read data and it is possible to control max power.
Hello everyone, sorry this is an online translation, I wanted to join the discussion because I also have a Growatt Min 3600TL-XH inverter, and I connected it to HA via the elfin EW11 converter, my inverter has a dedicated modbus port for monitoring on pins 3-4 of the Sys-Com connector, after setting the correct parameters for the serial and creating all the modbus sensors on HA I can have all the information and I was able to use everything for the energy panel too.
I got something working here (TL3-S 7000) by using the waveshare RS485-ETH (C) and coding the modbus sensors directly in configuration.yaml.
RS485 A-B connected directly to the Waveshare A-B.
More details later after reviewing the setup tomorrow - i also might try solax (HACS version).
Care to share? I struggle to read information, while i know my setup should work because I can get values through commandline on my mac. I have the exact same inverter as you, so would be nice to compare.
do you know which firmware version you have and which documentation do you use?
Is this integration reading out the inverter daily generated? And is that “reset” everyday?
I read the modbus via esphome and the growatt integration and recently after an update of esphome it does not give me a daily generated anymore but instead if adds it from then to the value from before.
Seaking support with esphome but they say “it is what the inverter sends back…”.
