Hello everybody,
I replaced connected GU10 spots in my house in the living/dining room.
They are Philips Hue compatible, so I’m using them with that for now but I’m going to switch to Home Assistant.
The downside is that the power must always be connected for them to work. I have manual switches that I no longer use (because if I press them, it cuts the power to the GU10).
What type of equipment do you recommend? I would ideally like to make my current switches “disappear”. This must not “cut” the power.
Also, I would like it to be well integrated. Currently I have Switch + socket combinations.
What are your recommendations?
THANKS
