Guage card cropping at top and bottom
Hi all,
I’m running HA 2024.8.1. No themes are selected, browser and OS set to 100% font size. Using the standard gauge lovelace card and setting it to 2x2 in the layout. No other customisations made. Cleared cache, restarted HA, tried a couple of browsers. Checked my profile theme is set to default / auto.
The top and bottom are getting cropped on any gauge that’s 2x2. Is this a ‘supported’ size without tweaking something?
Have I done something ‘wrong’ or missed something?
type: gauge
needle: true
severity:
  green: 200
  yellow: 500
  red: 1000
min: 50
max: 3000
unit: W
entity: sensor.frient_power_meter_power
name: 'Current Use: Electricity'
layout_options:
  grid_columns: 2
  grid_rows: 2
Thanks.
I came here to find an answer to this, too.
You are using sections and with 2024.9 you can now change gri and columns
Thanks!
I have just installed the update, but I cant change the hight of the rows. I can give the card another row, and that helps with cropping, but I need to actually make the gauge smaller, not make the holding block bigger.
Then I only know the custom gauge card but this has a different use of layout/coloring. This has a ‘scale’ in px
