The configuration options for that TP-Link router are very limited. Putting IoT devices onto a separate WiFi network is a good idea, until you would then need to communicate with those devices. Maybe it works without allowing access from the guest network into your main network, but if not, then you may need to open up access from the guest network into the main network which makes the separation less useful.
Also, what you normally want to do is to cut off IoT devices from “calling home”, i.e. restricting their Internet access, which does not seem to be possible on that TP-Link router.
There is a good 3-part series about building a secure and reliable network including VLANs, starting here: https://youtu.be/ufJ3dPAgFiM
I have a Deco M5 system, same issue. It appears with my iot on the guest, nothing can access them. My HA cannot ping them, so I can’t use localtuya on them.
It sounds like my choices are
no localtuya, use cloud which is really slow, slower than tuya’s own app
put all my iot on the main network - can I trust them with access to my nas etc?
I’m definitely not buying unifi or other extra hardware. Is this right?
I’m letting iot “calling home” now anyway. Just worried some rogue device gets hacked, then hacker can access my whole network.
