Guest NFC Share Wifi callback to HA
I´m a bit new on NFC but from what i can understand there is a standard to share Wifi using NFC much like there is for QR codes.
I also noticed that HA has a way to trigger an automation by using an url to the HA interface /tag/XXX
What i haven’t figured out is if the standards allow for two methods to be run or a callback url inside the Wifi tag.
What i want to achieve is when a guest scans a NFC tag to connect to the Wifi i want to run a automation inside HA.
Anyone with enough NFC knowledge around to know?
