I have been testing Hassio from a VM(Linux). All seems to go well until I try to add the following items and restart -
I didn’t enable ssh or samba but can get to the VM.
If I run the following - homeassistant logs
I see a Syntaxerror: invalid syntax with file /config/custom_components/plex_recenlty_added/init.py, line 7
Also if I run supervisor logs i get -
Error (MainThread) [hassio.homeassistant] Invalid Home Assistant config found!
Anyway to fix this with my current setup or do I need to start from scratch?
