GUI Configuration of History Stats Helper
I have just started playing around with history stats helper. I can create the helper just fine from the GUI. But once created I can only seem to edit the options (for time) and not the entity it tracks and the state? Is there a reason for this or am I doing something stupid?
hey, did you ever work this out? stuck at same point. I couldn’t find them in the config files either…
It was an intentional limitation based on an assumption that a user will never change an entity but may wish to play with a period. In case of a need to change an entity - a new helper is supposed to be created.
There is a corresponding closed issue in core GitHub.
OK thanks - does that apply to all helpers? Happy to work round it but not knowing were to find it was killing me!
No idea. Almost not using UI for helpers.
Imho a workflow depends on a particular integration.
