I am totally new to HA but I will build the maddafakka automation from hell. Just need to get past the first obstacles.
So this will be a small thing for you guys but I cannot start the Configuration GUI. I press the start button but nothing happens. Not in the log either. Probably a rookie misstake.
Freddie,
Which browser are you using. The newer versions 59.1 and 60 would not display everything under internet explorer. I opened hassio.local:8123 with chrome and everything appeared correctly.
I have tried Chrome and Safari. Same on both. The version I am using is 0.60
I click Hass.io->Configurator
Then I see Info and under info I see a couple of things. For example which version 0.2.3 and also State which is set to Stopped and when I press the Start button, nothing happens.
Then we have the Options section and it is here that I cannot edit anything. This is what I have:
“username”: “admin”,
“password”: null,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“ssl”: false,
“allowed_networks”: [
“192.168.0.0/16”
“banned_ips”: [
“8.8.8.8”
“banlimit”: 0,
“ignore_pattern”: [
“pycache”
“dirsfirst”: false
