Hi Home Assistant Community
I have been using HA for quite a number of years, not having made any significant changes over the last 2 years or so. For the interface I have been using on different devices, I have developed quite a number of card-templates, e.g. a slider template, a header template, etc.
After having read through the documentation of the new dashboard apporach and looking at some videos, I decided the re-design my dashboards I am using for various devices. Of course, I want to use the UI editor, as it seems to be quite fast and comfortable to work with that.
Having said that, I would like to continue using some of the card-templates and also developing new card-templates for the new dashboards. Here is my problem, I cannot get these templates integrated into my new dashboards.
I have a folder of templates (button-card-templates), e.g. a file called slider-light.yaml, within the file, I have a card-template defined (copied from the mushroom interface discussion, I would be nowhere without this community, thanks to everybody!) as follows:
slider_light:
variables:
var_entity: 'var_entity'
var_name: 'var_name'
name: '[[[ return variables.var_name ]]]'
custom_fields:
slider:
card:
type: vertical-stack
cards:
- type: custom:my-slider-v2
entity: '[[[ return variables.var_entity ]]]'
colorMode: brightness
styles:
container:
- border-radius: 100px
- overflow: visible
- background: none
card:
- height: 40px
- padding: 0 20px
- background: var(--brightness)
track:
- overflow: visible
- background: none
progress:
- background: none
thumb:
- background: var(--black)
- top: 2px
- right: '-18px'
- height: 36px
- width: 36px
colorMode: temperature
styles:
container:
- overflow: visible
- background: none
card:
- height: 40px
- padding: 0 20px
- background: var(--temperature)
track:
- overflow: visible
- background: none
progress:
- background: none
thumb:
- top: 2px
- right: '-18px'
- height: 36px
- width: 36px
styles:
grid:
- grid-template-areas: '"n" "slider"'
- grid-template-columns: 1fr
- grid-template-rows: 1fr min-content min-content
card:
- font-family: Metropolis-Regular.otf;
- background: var(--brightness-tint)
- padding: 16px
- '--mdc-ripple-press-opacity': 0
name:
- justify-self: start
- font-size: 14px
- margin: 4px 0 12px 0
- color: var(--contrast20)
Within the UI editor, I opened the main yaml file (Raw Configuration Editor) and tried two things:
- integrate the folder at the very top of the yaml file and later referred to it:
button_card_templates: !include_dir_merge_named integrations/common/button-card-templates/
- title: Office
path: office
icon: mdi:desk
cards:
- type: custom:button-card
template: slider_light
variables:
var_entity: light.az_fenster_links
var_name: fensterlampe
which did not work
- I included the template definition itself in the yaml file at the very top and then referred to it later
button-card-templates:
- slider_light: null
variables: null
var_entity: var_entity
var_name: var_name
custom_fields:
slider:
card:
cards:
- title: Office
path: office
icon: mdi:desk
cards:
variables:
I also tried to integrate the folder via the configuration.yaml, as well as the lovelace,yaml, and frontend.yaml
None of that worked. I am sure we can use somehow the -card-templates in the UI setup, but I am just not finding a way to do so.
I am thankful for every hint, leading me to the solution
Thanks for helping!
