It would be nice to have the ability to specify from the Devices/Entities area, on whether or not you would like a specific entity to be logged by the recorder or not, as the current method of adding the entity to the exclude section of the record in the configuration.yaml can be rather long winded at times when you have several entities.
My thought was to have it similar to the “Entity Status” in “Advanced Settings” of an Entity, whereby you could have either “Include” or “Exclude” as options for logging. This means that you don’t need to flip between the the Entity itself to get the entity name and then back to the yaml file to add it to the list. I understand that a reboot is usually required after this, but then a small side note could be added to let the user know this when they have changed the logging levels from that menu.
