So I’m using the HA gui to create all my automations, and the one thing I am struggling with at the moment is implementing NOT and OR.
I this case I have a dropdown select option, one of which is Shower. If I have selected “Shower” mode I don’t want the automation to fire. If it’s in any other mode then yes, proceed. Except for some reason this just doesn’t fire off at all. Fairly basic question, sorry.
choose:
- conditions:
- condition: trigger
- condition: not
conditions:
- condition: state
entity_id: input_select.dropdown
state: Shower
sequence:
- service: timer.start
duration: '0:15:00'
entity_id: timer.pumppause
- service: input_select.select_option
option: Auto
default: []
Thank you, yes looked at the trace, it just stops at the “top” so to speak, when I remove the “NOT shower” condition it proceeds perfectly.
Tried reloading automations, tried changing the dropdown selection to other options.
This is not (chuckle at ‘not’ pun here) the first time I have had issues with NOT and OR implementation in the GUI. Usually I have avoided them by creating choose options for when the automation should work.
