Odd things happening:
- GUI working
- I can toggle lights using GUI
- But can’t reach addons like addguard.
- In GUI I can see the logs of HomeAssistant
- In GUI I can’t see all the other logs.
- Trying to reach RPI with Putty. But can’t reach it.
Running HASS on RPI4.
I could hard reset the host, offcourse. But before I do that… I want to check the forum for insights.
Can you point me in the right direction?
- Core 2023.11.2
- Frontend 20231030.2
Logger: homeassistant.components.hassio
Source: components/hassio/websocket_api.py:138
Integration: Home Assistant Supervisor
First occurred: 12 nov. 2023 at 14:31:13 (39 occurrences)
Last logged: 22:03:07
Failed to to call /host/info -
Failed to to call /backups -
Failed to to call /network/info -
Failed to to call /os/info -
Failed to to call /info -
Logger: homeassistant.components.hassio.http
Source: components/hassio/http.py:190
Integration: Home Assistant Supervisor (documentation, issues)
First occurred: 20:12:25 (11 occurrences)
Last logged: 21:30:36
- Client error on api supervisor/logs request Connection timeout to host http://172.30.32.2/supervisor/logs
- Client error on api host/logs request Connection timeout to host http://172.30.32.2/host/logs
- Client error on api dns/logs request Connection timeout to host http://172.30.32.2/dns/logs
- Client error on api audio/logs request Connection timeout to host http://172.30.32.2/audio/logs
- Client error on api multicast/logs request Connection timeout to host http://172.30.32.2/multicast/logs
