Above is my groups.yaml file. I am trying to get the lovelace UI to show open if any of the windows are open.
Instead it shows:
I tried changing the groups.yaml to “binary_sensor” but it didn’t work. Any help would be appreciated.
Instead it shows:
I couldn’t find an answer to this either so I just used a template binary sensor, albeit for only 2 windows (to combine 2 opening windows in a single frame).
You could just add all the binary sensors to the value_template with ‘or’
living_room_window:
friendly_name: "Living Room Window"
device_class: window
value_template: "{{ is_state('binary_sensor.living_room_window1', 'on') or is_state('binary_sensor.living_room_window2', 'on') }}"
Thanks for looking into it. I have been mad searching all over these forums with no luck.
A template sounds like a great solution. Thanks for the help.
An easy template:
window_status:
friendly_name: "Window Status"
entity_id:
- binary_sensor.back_window_... etc
value_template: "{{ expand('group.window_status') | selectattr('state','eq','on') | list | count > 0 }}"
You’ll need to add each sensor individually inside the group the entity_id attribute.
I have been trying to figure this code out.
I get the error:
Log Details (ERROR)
Wed Sep 04 2019 14:35:02 GMT-0500 (Central Daylight Time)
Invalid config for [sensor.template]: [window_status] is an invalid option for [sensor.template]. Check: sensor.template->window_status. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
My configuration.yaml
window_status:
entity_id:
- binary_sensor.back_window_2_contact
- binary_sensor.bedroom_window_3_contact
- binary_sensor.dining_room_contact
- binary_sensor.front_bedroom_contact
- binary_sensor.front_window_1_contact
- binary_sensor.front_window_2_contact
- binary_sensor.nursery_window_1_contact
- binary_sensor.nursery_window_2_contact
- binary_sensor.office_window_1_contact
- binary_sensor.office_window_2_contact
This is what I was attempting. I tried to put it outside of the sensor and without the - platform: template but it didn’t like that either.
This is my groups.yaml but I don’t think I need it
Contact Sensors:
entities:
you’re missing a space, and the sensors section header.
sensors:
window_status:
entity_id:
This looks great, I’m gonna use this for my alarm groups and dorr and window groups - Thanks @petro
Log Details (ERROR)
Wed Sep 04 2019 16:32:04 GMT-0500 (Central Daylight Time)
I get a similar error. I copied and pasted your code in.
sensors:
window_status:
entity_id:
I deleted the groups.yaml and now get:
Wed Sep 04 2019 16:45:22 GMT-0500 (Central Daylight Time)
Invalid config for [sensor.template]: value is not allowed for dictionary value @ data['sensors']['window_status']['device_class']. Got 'window'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/`
Im trying!
I took out the device_class and tried to put under customize.yaml. It didn’t throw errors but now it says false
customize.yaml
sensor.window_status:
configuration.yaml
sensors:
window_status:
entity_id:
Something is very wrong somewhere because the error messages don’t appear to be identifying valid problems.
window_status as an ‘invalid option’.groups.yaml shouldn’t cause a complaint about device_class.device_class is a valid option for a Template Sensor.There’s a missing clue to explain these strange results …
Out of curiosity, which version of Home Assistant are you using?
Do you have other sensors defined in configuration.yaml?
Surely you need to keep the group as the value_template references it ?
I figured group.window_status made a group from the entities listed in the window_status?
Yes, the group is needed but without it the template will simply fail quietly. The weird thing is that deleting group.yaml caused a seemingly unrelated error message concerning the template sensor’s device_class. That’s a puzzling result and indicative that there’s something else happening here that hasn’t been revealed yet.
No it doesn’t. You must explicitly define the group if you intend to refer to it within the template.
I’ll repeat my previous question, do you have other sensors defined in configuration.yaml or is this Template Sensor the only one?
Also, wouldn’t a template binary sensor be better suited here ?
Trying again!
groups.yaml
Contact Sensors:
entities:
configuration.yaml
sensors:
window_status:
entity_id:
Error Log
Log Details (ERROR)
Wed Sep 04 2019 17:18:01 GMT-0500 (Central Daylight Time)
I included all my sensor code block just in case but I don’t see any conflicts there.
group needs to be:
group:
entities:
OK so done this myself and works fine (note slightly different group name as I already have that group)
Binary Sensor
binary_sensor:
window_status:
entity_id:
- binary_sensor.living_room_window
- binary_sensor.kitchen_window
- binary_sensor.toilet_window
- binary_sensor.bathroom_window
- binary_sensor.ensuite_window
- binary_sensor.alices_window
- binary_sensor.bens_window
value_template: "{{ expand('group.windows') | selectattr('state','eq','on') | list | count > 0 }}"
Group
windows:
view: false
entities:
