Guide for CCTV Snapshot on motion, send to Google Generative AI & get notification with description & snapshot
I had to split the image and text into seperate notifications to get the full text to show.
Did you figure out a solution, I also have Eufy cameras and this guide does not work my. The wireless cameras just return the last event image when taking a snapshot via HAAS and the wired cameras don’t return any data when taking a snapshot.
I’m struggling with Eufy too. I have setup the blueprint and add the doorbell and sensor but I get this message which makes me think that there is no image?
Executed: 1 January 2025 at 16:26:08
Error: Action google_generative_ai_conversation.generate_content not found
Check the trace of the script. You’ll see what is happening there.
Brilliant! This is excellent. Thank you so much.
All setup - I’ve got it working on Home Assistant and coming through to my phone perfectly. I’ve also now got Telegram setup - I thought that’d be useful as I can then save the image and see the full text. The text is being received but I’m not getting the image sent through to Telegram.
Any thoughts - because it’s setup as a bot does that mean it’s not receiving the image? Is there a way to overcome this (or at least troubleshoot). The photo is definitely there as I can see it in the snapshot folder.
Thanks!
Hi all,
Im having issues getting this to work with my google hello doorbell (battery).
The first issue is that when the doorbell sees motion, it does not send a notification to my phone at all.
Even though i do get the usual google home notification.
The second issue is when i click run actions in the blueprint screen i do get a notification on my phone straight away but the picture is black and i get the no obvious motion text.
I have installed the Nest integration and both my doorbell and home hub cameras are working fine in HA.
Im very new to HA (3 days) so im not to sure where i should be looking for the answer.
Im happy to post screen shots of the traces or yaml if someone can let me know how to do that here.
Thanks in advance
Hi @TrOjAn
Would you mind please sharing both your automation & script?
Im trying to get my notifications sent to pushover. Ive copied your code and it send the notification but no image is attached I’m a little lost on how I get the image sent over.
My images are stored in /local/tmp/Frontleft-snapshot.jpg
Any ideas what I’m doing wrong?
I get this error when I try and save it.
Message malformed: template value should be a string for dictionary value @ data[‘actions’][3][‘data’]
Many thanks
action: notify.pushover
metadata: {}
  title: "{{ motion_name }} Detected"
  target: fold4
  message: >-
    {{ generated_content['text'] }} This message was generated with Google
    Generative AI.
    attachment: "{{ /local/tmp/Frontleft-snapshot.jpg }}"
    sound: cashregister```
This is the Script
alias: Doorbell Google AI
sequence:
  - metadata: {}
      filename: ./www/snapshots/doorbell_snapshot1.jpg
    enabled: true
    action: camera.snapshot
      entity_id: camera.doorbell_clear_2
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 500
    enabled: true
  - metadata: {}
      filename: ./www/snapshots/doorbell_snapshot2.jpg
    enabled: true
  - delay:
      hours: 0
      minutes: 0
      seconds: 0
      milliseconds: 500
    enabled: true
  - metadata: {}
      filename: ./www/snapshots/doorbell_snapshot3.jpg
    enabled: true
  - metadata: {}
      prompt: >-
        Motion has been detected at the front of the house, compare what you see
        in the following sequence of images from my doorbell camera. If a person
        is walking towards or away from the camera, describe them in detail. Do
        not describe stationary objects or buildings or people walking left to
        right or right to left. If possible record vehicle registration numbers.
        If you see no obvious causes of motion, reply with "No Obvious Motion
        Detected."
      image_filename:
        - ./www/snapshots/doorbell_snapshot1.jpg
        - ./www/snapshots/doorbell_snapshot2.jpg
        - ./www/snapshots/doorbell_snapshot3.jpg
    response_variable: generated_content
    action: google_generative_ai_conversation.generate_content
  - if:
      - condition: template
        value_template: "{{ 'No Obvious Motion Detected.' in generated_content.text }}"
    then:
      - stop: ""
    else: null
  - metadata: {}
    action: telegram_bot.send_photo
      title: Doorbell Motion Detected
      caption: "{{generated_content['text'] }}"
      data: null
      authentication: digest
      file: /config/www/snapshots/doorbell_snapshot2.jpg
mode: single
This is the Automation
description: ""
triggers:
  - type: turned_on
    device_id: d8ccb88c128b0b47abd14a9a61
    entity_id: 1c3a3a0c933529c408ee6e6785d
    domain: binary_sensor
    trigger: device
conditions: []
actions:
  - metadata: {}
    data: {}
    action: script.camera_1_snapshot_ai_notification
mode: single
Double check the file path, the format you have lists it as a variable, which is not.
can you see the image being created / stored in that location?
metadata: {}
  target: fold4
  message: >-
    Generative AI.
    attachment: /local/tmp/Frontleft-snapshot.jpg
The above assuming that HA has access to that location and the image is there as well.
This was all working well until yesterday. When viewing logs, I find the error that I’m exceeding my Gemini quota. The Gemini API page tells me that “A potential violation of our Acceptable Use Policy has been detected for a project you own.”
WTH?
I’m getting the same error, and reviewing the Gemini Dashboard there is a notice to say the account has been suspended - asking you to review the Terms of Service and Acceptable use policy to while you can they lodge a request for review of the suspension, which I’ve done but no response from Google as yet.
Seems there are more people with the same error out of nowhere Google Generative AI - 429 Error
I’ve appealed also. Don’t know how I violated terms. Says I exceeded quota.
" Logger: custom_components.llmvision.config_flow
Source: custom_components/llmvision/config_flow.py:258
integration: LLM Vision (documentation, issues)
First occurred: 1:24:21 PM (1 occurrences)
Last logged: 1:24:21 PM
Validation failed: Quota exceeded for quota metric ‘Generate Content API requests per minute’ and limit ‘GenerateContent request limit per minute for a region’ of service ‘generativelanguage.googleapis.com’ for consumer ‘project_number:45xxxxxxxxxxx’."
Very generic error message, I looked over the API console and logging and could not find anything that pointed to a reason.
HA has sent 304 Request via the API in the last 30 days, that alone makes it implausible to have exceeded the quotas.
Will see what they say, in the next couple of days else create a new project or move to an alternative.
Thanks for this, I got it working with pushover now including the image. Couldn’t test for a few days with receiving the violation error. Now that’s been removed it works a treat. thanks
Hi folks, thank you for the script and all working however on my iOS device when I click on it it disappears, how can I gt it view the clip or video clip as an action button. Any ideas how it can be programmed.
To which app are you sending the notifications?
The HA Companion app has some limitations, do recall this may be one of them, hence the use of other apps such as Telegram, Pushover, etc. to deliver some notification.
Thank you BambamNZ. Using the companion app but will try Telegram .
Hy, i have this error :slight_smile:
L’automazione “Camera 1 - Snapshot on motion” (automation.camera_1_snapshot_on_motion ) ha un’azione sconosciuta: script.camera_1_snapshot_ai_notification .
can anyone help me? Thank you
