Oh I struggled so hard with ngnixβ¦
This should be a complete walkthrough from purchasing your own domain, Getting a wildcart cert with 15 jears of validity and making it more secure with NGNIX
First! Big thanks to @Tinkerer whom I took some nerves while troubleshooting my first few attempts @Ludeeus where roundabout happened the same and also recommended this setup!
Edit: after 6 Monts of using this setup it finaly come to my attention that the real IP`s are not beeing forwarded.
sadly you now also have to configure nginx.conf, create a bash script and run it via chrontab.
Just make this changes after you gone through the whole process.
Cloudflare IP`s could change- so i added here @sjabby chrontab setup insted of just including the servers one time.
First a bash script wich ll take the ip list from cloudflare and creates cf_real-ip.conf
sudo nano /etc/nginx/nginx.sh
#!/usr/bin/env bash
curl -s 'https://www.cloudflare.com/ips-v4' > /tmp/cf.txt
curl -s 'https://www.cloudflare.com/ips-v6' >> /tmp/cf.txt
sed 's/^/set_real_ip_from /' /tmp/cf.txt > /tmp/cf2.txt
sed -e 's/$/;/' /tmp/cf2.txt > /etc/nginx/cf_real-ip.conf
Save it, make it executable with sudo chmod +x /etc/nginx/nginx.sh
create a root chrontab with sudo crontab -e I gone for:
0 4 15 * * /etc/nginx/nginx.sh
wich says every 15th of the month at 4 in the morning (create a sheudle as you please )
now to your ngnix.conf
sudo nano /etc/nginx/nginx.conf
inside the http block we have to add:
include /etc/nginx/cf_real-ip.conf; real_ip_header X-Forwarded-For;
Wich schould then look like this :
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
Done!
this will redirect the real IP`s to your HA instance
1: Get a Domain where you can change the name servers
Route53 from AWS is a pretty inexpensive way to go. but youβre free to use whichever domain registration you like as long you can update the name servers
https://console.aws.amazon.com/route53
2: Create a Cloudflare Account And change the name servers
there you already can add your new site - Now it the time to change the name servers.
In the case that you used Route53 - here another tutorial how to change the name servers
The change ll take some hours. Its depending on the TTL value of your domain.
24 hours is a typical default. So check back later
3: Create the certificates and copy them to your pi
When you get the E-Mail from Cloudflare that your name servers are updated, go to your cloudflare home tab, your domain, up to [Crypto] and a little further down Origin Certificates and hit [create Certificate]
RSA is fine and the settings should be already good - But check that there is *.domain.com & domain.com
While its open - SSH into your pi
$ sudo nano /etc/ssl/certs/cert.pem
and past the upper part in ( your ssl_certificate) ctrl+x and save & yes you should know it
The lower part is your key! so again
$ sudo nano /etc/ssl/private/key.pem
and past the lower part in
back it up again - on your drive or whatever - It ll be only shown once.
4: set up NGNIX
First, install NGINX. On any Debian based distribution (such as Raspbian) you do that with:
$ sudo aptitude update
$ sudo aptitude install nginx
If you get an error about aptitude not being found then:
$ sudo apt-get install aptitude
then try again.
just to play save
$ sudo systemctl stop nginx
If your configuration locks like this tree youβre golden
(sudo apt-get install tree - not nessasary at all but you see here - all the files are here )
pi@hassbian:~ $ tree /etc/nginx/ /etc/nginx/ βββ conf.d βββ fastcgi.conf βββ fastcgi_params βββ koi-utf βββ koi-win βββ mime.types βββ modules-available βββ modules-enabled β βββ 50-mod-http-auth-pam.conf -> /usr/share/nginx/modules-available/mod-http-auth-pam.conf β βββ 50-mod-http-dav-ext.conf -> /usr/share/nginx/modules-available/mod-http-dav-ext.conf β βββ 50-mod-http-echo.conf -> /usr/share/nginx/modules-available/mod-http-echo.conf β βββ 50-mod-http-geoip.conf -> /usr/share/nginx/modules-available/mod-http-geoip.conf β βββ 50-mod-http-image-filter.conf -> /usr/share/nginx/modules-available/mod-http-image-filter.conf β βββ 50-mod-http-subs-filter.conf -> /usr/share/nginx/modules-available/mod-http-subs-filter.conf β βββ 50-mod-http-upstream-fair.conf -> /usr/share/nginx/modules-available/mod-http-upstream-fair.conf β βββ 50-mod-http-xslt-filter.conf -> /usr/share/nginx/modules-available/mod-http-xslt-filter.conf β βββ 50-mod-mail.conf -> /usr/share/nginx/modules-available/mod-mail.conf β βββ 50-mod-stream.conf -> /usr/share/nginx/modules-available/mod-stream.conf βββ nginx.conf βββ proxy_params βββ scgi_params βββ sites-available β βββ default βββ sites-enabled β βββ default -> /etc/nginx/sites-available/default βββ snippets β βββ fastcgi-php.conf β βββ snakeoil.conf βββ uwsgi_params βββ win-utf
you see [/etc/nginx/sites-enabled/default] points to [sites-available/default]
so lets change it to the new config;
(actualy from Reverse proxy using NGINX - Community Guides - Home Assistant Community )
( Ctrl+K to cut the whole line)
$ sudo nano /etc/nginx/sites-available/default
and change the server name - to the domain of your certificate
just copy the text from [Origin Certificates] Hosts
( NGINX tests the requestβs Host header field against the server_name )
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
server {
### Update this line to be your IP at the end the ;
server_name *.example.org example.org;
# These shouldn't need to be changed
listen [::]:80 default_server ipv6only=off;
return 301 https://$host$request_uri;
server {
### Update this line to be your IP again dont forget at the end the ;
# Ensure these lines point to your SSL certificate and key (step 3)
ssl_certificate /etc/ssl/certs/cert.pem;
ssl_certificate_key /etc/ssl/private/key.pem;
listen [::]:443 default_server ipv6only=off; # if your nginx version is >= 1.9.5 you can also add the "http2" flag here
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl on;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_session_cache shared:SSL:10m;
proxy_buffering off;
location / {
proxy_pass http://127.0.0.1:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
the 2 server names have to be identical - otherwise it gets you an error
the proxy_pass is passing all requests processed in this location to the proxied server at the specified address - so you could also run this from another device and route it to your Home Assistant
Check the syntax with
$ sudo nginx -t
Restart NGINX with
$ sudo systemctl restart nginx
short check in the error logs
$ sudo tail /var/log/nginx/error.log
Now go to your browser - put in the IP of your pi (without port) and you should be already be redirected to Home Assistant
5: Change the configuration and update Cloudflare
therefore check out the Docks - From 0.53 on Ludeuus custom cloudflare component got a official one
go to https://dash.cloudflare.com and klick Get your API key you want the Global API Key
Change the tab to DNS - and create a A record for the subdomain you want to use
For example βahsdzukadgzo8912378β let it point to any ip (it has to be set up for the Home assistant component - otherwise it cant update )
and change the configuration accordingly
zone: example.com
records:
- ahsdzukadgzo8912378
under
http: in your configuration.yaml
get rid of the SSL certificates - NGINX takes care of this now.
Update your base url and add trusted_proxies & use_x_forwarded_for: True
for example:
http:
api_password: !secret http_password
# ssl_certificate: !secret ssl_certificate
# ssl_key: !secret ssl_key
trusted_proxies:
- 127.0.0.1
base_url: !secret base_url
Now change the Port forwarding settings on the Router to [80>80] and [443>443]
and get rid of from [8123>8123]
When you used the hassbian-config duckdns tool get rid of the cron job while youβre on it
$ sudo crontab -u homeassistant -e
Tutorials I used to put this together
