Home Assistant on M1 Mac is not well documented. I hope we can change that.
Please criticize and improve this method.
No warranties, make backups, expect everything.
My user is called “server”, change accordingly.
Why this method
- Docker on macOS can’t use USB/Serial devices.
- M1 Macs use virtual machines in emulation mode which is not efficient (25 % CPU with UTM on idle)
- Raspberry Pi and similar devices can’t offer the flexibility and power of an existing Mac.
Install Node.JS LTS for macOS
Install Homebrew
/bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
Install Python3 on macOS
brew install python3
Install libjpeg-turbo
brew install jpeg-turbo
Install make - required since 2023.12 uses make to install zlib-ng
brew install make
Install python virtual environment (venv) and Home Assistant
pip3 install virtualenv
cd ~/
python3 -m venv homeassistant
source homeassistant/bin/activate
pip3 install homeassistant
deactivate
Config is saved in ~/.homeassistant
Install Yarn compiler
npm install --global yarn
Compile ZWaveJS2MQTT for M1
git clone https://github.com/zwave-js/zwavejs2mqtt
cd zwavejs2mqtt
yarn install
yarn run build
Manual start or restart (optional)
cd ~/zwavejs2mqtt
yarn start
source ~/homeassistant/bin/activate
~/homeassistant/bin/hass
Run Home Assistant and ZWaveJS2MQTT as services at startup
start service
launchctl load /Users/server/Library/LaunchAgents/org.homeassistant.plist
launchctl load /Users/server/Library/LaunchAgents/org.zwavejs2mqtt.plist
stop service
launchctl unload /Users/server/Library/LaunchAgents/org.homeassistant.plist
launchctl unload /Users/server/Library/LaunchAgents/org.zwavejs2mqtt.plist
manual start
launchctl start org.homeassistant
launchctl start org.zwavejs2mqtt
manual stop
launchctl stop org.homeassistant
launchctl stop org.zwavejs2mqtt
Make
~/Library/LaunchAgents/org.homeassistant.plist
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>AbandonProcessGroup</key>
<false/>
<key>EnvironmentVariables</key>
<dict>
<key>LC_CTYPE</key>
<string>UTF-8</string>
<key>PATH</key>
<string>/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:$PATH</string>
</dict>
<key>KeepAlive</key>
<dict>
<key>SuccessfulExit</key>
<false/>
</dict>
<key>Label</key>
<string>org.homeassistant</string>
<key>Program</key>
<string>/Users/server/.homeassistant/scripts/ha_agent.sh</string>
<key>RunAtLoad</key>
<true/>
</dict>
</plist>
Make
~/Library/LaunchAgents/org.zwavejs2mqtt.plist
<dict>
<false/>
<dict>
<key>LC_CTYPE</key>
<key>PATH</key>
<string>/usr/local/bin/:/usr/bin:/usr/sbin:/sbin:$PATH</string>
</dict>
<dict>
<false/>
</dict>
<key>Label</key>
<string>org.zwavejs2mqtt</string>
<key>ProgramArguments</key>
<array>
<string>bash</string>
<string>-c</string>
<string>cd /Users/server/zwavejs2mqtt; yarn start</string>
</array>
<true/>
</dict>
</plist>
Make
~/.homeassistant/scripts/ha_agent.sh
#!/bin/bash
sleep 60
source /Users/server/homeassistant/bin/activate
/Users/server/homeassistant/bin/hass
Make it executable:
chmod 711 ~/.homeassistant/scripts/ha_agent.sh
Backup procedure
Make sure to backup these folders regularly:
~/.homeassistant
~/homeassistant
~/zwavejs2mqtt
Or automate it:
caffeinate rsync -E -a --delete "/Users/server/homeassistant" "/Volumes/Backup/server"
caffeinate rsync -E -a --delete "/Users/server/.homeassistant" "/Volumes/Backup/server"
caffeinate rsync -E -a --delete "/Users/server/zwavejs2mqtt" "/Volumes/Backup/server"
Update procedures
Update Homebrew and all its packages (including Python3) and clean caches
brew update
brew upgrade
brew autoremove
brew cleanup --prune=all
Update Node.JS and npm
sudo npm install --global yarn
sudo npm install -g npm@latest
sudo npm cache clean -f
sudo n stable
Stop services
Update Python virtual environment (venv)
pip3 install --upgrade pip
python3 -m venv ~/homeassistant
Install Home Assistant Core
rm -rf ~/homeassistant_old
mv ~/homeassistant ~/homeassistant_old
cd ~/
deactivate
Update ZWaveJsMQTT
rm -rf ~/zwavejs2mqtt_old
cp ~/zwavejs2mqtt ~/zwavejs2mqtt_old
cd ~/
#sudo npm install --global yarn
cd ~/zwavejs2mqtt
yarn install
yarn run build
Update custom addons
~/.homeassistant/custom_components
Automation example - be very careful and adapt
rm -rf ~/Desktop/tmp
mkdir ~/Desktop/tmp
cd ~/Desktop/tmp
curl -L "https://github.com/USER/REPOSITORY/archive/refs/heads/NAME.zip" >file.zip
unzip file.zip
rm file.zip
mv * git_tmp
mv git_tmp/custom_components/*/ ~/Desktop/ha_tmp
rm -rf ~/.homeassistant/custom_components/REPOSITORY
mv ~/Desktop/ha_tmp/* ~/.homeassistant/custom_components
rm -rf ~/Desktop/ha_tmp
Restart Services after update or restart macOS
Quirks with macOS
Add this code to configuration YAML for video support on HomeKit
ffmpeg:
ffmpeg_bin: /opt/homebrew/bin/ffmpeg
PLEASE report any bugs or improvements that I could do. I will add all improvements to this page. ![]()
