This small guide will help you quickly set up your newly rooted (and integrated via HACS) Toon.
My previous configuration consisted of the DSMR integration in sensors.yaml. I got this through a Wemos with ESP Easy (source).
- platform: dsmr
host: !secret P1_gateway_ip
port: 8088
dsmr_version: 4
and the data collection in configuration.yaml
utility_meter:
hourly_energy_offpeak:
source: sensor.energy_consumption_tarif_1
cycle: hourly
hourly_energy_peak:
source: sensor.energy_consumption_tarif_2
cycle: hourly
daily_energy_offpeak:
cycle: daily
daily_energy_peak:
cycle: daily
monthly_energy_offpeak:
cycle: monthly
monthly_energy_peak:
cycle: monthly
daily_gas:
source: sensor.gas_consumption
cycle: daily
monthly_gas:
cycle: monthly
Since these sensors were already widely used throughout my Lovelace, I wanted to write a wrapper for the given Toon sensors to be compatible with my previous DSMR configuration. So in sensors I first added the rooted Toon with integrations from HACS (one of which: toon_climate)
sensors:
toon_driewegklep:
friendly_name: 'Driewegklep'
value_template: >-
{% if is_state_attr('climate.toon','burner_info', 0) %}
Neutraal
{% elif is_state_attr('climate.toon','burner_info', 1) %}
CV
{% elif is_state_attr('climate.toon','burner_info', 2) %}
Warm Water
{% endif %}
- platform: toon_smartmeter
host: !secret toon_ip
port: 80
scan_interval: 10
resources:
- gasused
- gasusedcnt
- elecusageflowpulse
- elecusagecntpulse
- elecusageflowlow
- elecusagecntlow
- elecusageflowhigh
- elecusagecnthigh
- elecprodflowlow
- elecprodcntlow
- elecprodflowhigh
- elecprodcnthigh
- elecsolar
- elecsolarcnt
- heat
- platform: toon_boilerstatus
port: 80
scan_interval: 10
resources:
- boilersetpoint
- boilerintemp
- boilerouttemp
- boilerpressure
- boilermodulationlevel
- roomtemp
- roomtempsetpoint
And now finally the conversion of the new sensors to the previously used sensors:
# Convert Toon to DSMR values
sensors:
# Electricity
power_consumption:
friendly_name: Power consumption
unit_of_measurement: kW
device_class: power
value_template: "{{ (states('sensor.toon_p1_power_use_low')|float + states('sensor.toon_p1_power_use_high')|float) / 1000 }}"
energy_consumption_tarif_1:
friendly_name: Energy Consumption 1
unit_of_measurement: kWh
device_class: energy
value_template: "{{ states('sensor.toon_p1_power_use_cnt_low') |float }}"
energy_consumption_tarif_2:
friendly_name: Energy Consumption 2
value_template: "{{ states('sensor.toon_p1_power_use_cnt_high') |float }}"
energy_production_tarif_1:
friendly_name: Energy Production 1
value_template: "{{ states('sensor.toon_p1_power_prod_cnt_low') |float }}"
energy_production_tarif_2:
friendly_name: Energy Production 2
value_template: "{{ states('sensor.toon_p1_power_prod_cnt_high') |float }}"
# Gas
gas_consumption:
friendly_name: Gas consumption
unit_of_measurement: m3
value_template: "{{ states('sensor.toon_gas_used_cnt') |float }}"
hourly_gas_consumption:
friendly_name: Gas hourly consumption
value_template: "{{ states('sensor.toon_gas_used_last_hour') |float }}"
This was written for ha 0.117.5. I guess the template could be changed for 0.118, which now also accepts values instead of strings.
