[Guide] Train a Custom French Wake Word for Home Assistant with OpenWakeWord (Colab)
:rocket: Tired of “Hey Google” or “Alexa”?
Train your own French wake word (e.g., “Alexa”, “Jarvis”, “Lumière”) offline using OpenWakeWord + Piper TTS—directly in Google Colab!
:white_check_mark: No local setup needed (runs in the cloud)
:white_check_mark: Supports French (with fr_FR-upmc-medium voice model)
:white_check_mark: Export to .tflite for Home Assistant integration
:pushpin: Prerequisites
  • A Google account (to use Colab).
:hammer_and_wrench: Step 1: Open the Colab Notebook
  1. Open the Wake Word Training Environment.
  2. Click “Show code” (under the first cell) to reveal the script.
:wrench: Step 2: Replace the Code for French Support
Copy-paste this entire block to replace the default code:
(The script downloads a French TTS model and generates samples with proper resampling.)
# @title  { display-mode: "form" }
# @markdown # 1. Test Example Training Clip Generation
# @markdown Since openWakeWord models are trained on synthetic examples of your
# @markdown target wake word, it's a good idea to make sure that the examples
# @markdown sound correct. Type in your target wake word below, and run the
# @markdown cell to listen to it.
# @markdown
# @markdown Here are some tips that can help get the wake word to sound right:
# @markdown - If your wake word isn't being pronounced in the way
# @markdown you want, try spelling out the sounds phonetically with underscores
# @markdown separating each part.
# @markdown For example: "hey siri" --> "hey_seer_e".
# @markdown - Spell out numbers ("2" --> "two")
# @markdown - Avoid all punctuation except for "?" and "!", and remove unicode characters
import os
import sys
from IPython.display import Audio
if not os.path.exists("./piper-sample-generator"):
    !git clone https://github.com/rhasspy/piper-sample-generator
    !wget -O piper-sample-generator/models/fr_FR-upmc-medium.onnx 'https://huggingface.co/rhasspy/piper-voices/resolve/main/fr/fr_FR/upmc/medium/fr_FR-upmc-medium.onnx'
    !wget -O piper-sample-generator/models/fr_FR-upmc-medium.onnx.json 'https://huggingface.co/rhasspy/piper-voices/resolve/main/fr/fr_FR/upmc/medium/fr_FR-upmc-medium.onnx.json'
    !cd piper-sample-generator
    # Install system dependencies
    !pip install piper-tts piper-phonemize-cross
    !pip install webrtcvad
    !pip install 'torch<=2.5' torchvision torchaudio
if "piper-sample-generator/" not in sys.path:
    sys.path.append("piper-sample-generator/")
import generate_samples
target_word = 'alexa' # @param {type:"string"}
def text_to_speech(text):
    generate_samples.generate_samples_onnx(text = text,
                max_samples=1,
                length_scales=[1.1],
                noise_scales=[0.7], noise_scale_ws = [0.7],
                output_dir = './', batch_size=1, auto_reduce_batch_size=True,
                file_names=["test_generation.wav"],
                model="piper-sample-generator/models/fr_FR-upmc-medium.onnx"
text_to_speech(target_word)
Audio("test_generation.wav", autoplay=True)
What this does:
  • Downloads the French Piper TTS model (fr_FR-upmc-medium).
  • Generates a test audio clip of your wake word.
  • Plays the clip automatically for preview.
:microphone: Step 3: Test Your Wake Word
  1. Replace 'alexa' in target_word with your desired wake word (e.g., 'jarvis', 'lumière').
  2. Run the cell (:play_button: button).
  3. Listen to the generated clip. If it sounds wrong:
  • Try phonetic spelling (e.g., 'j_a_r_v_i_s' for “Jarvis”).
  • Adjust length_scales or noise_scales for clearer audio.
:open_file_folder: Step 4: Modify the Training Script
  1. In Colab’s file explorer (:file_folder: icon on the left), navigate to:
openwakeword/openwakeword/train.py
  1. Double-click to open the file, then replace its entire content with this optimized script (see below for key improvements).
Link to the modified script on Pastebin
Key Improvements in the New train.py:
Feature Why It Matters
French TTS support Uses fr_FR-upmc-medium.onnx by default.
Automatic resampling Ensures all clips are 16kHz (required for OpenWakeWord).
:warning: Note: The script automatically resamples audio to 16kHz. If you skip this, training will fail!
:rocket: Step 5: Train Your Model
  1. Run Step 1 and Step 2 in Colab to generate positive/negative samples.
  2. Run Step 3 to start training. The script will:
  • Save the best model as .onnx.
  • Convert it to .tflite (compatible with Home Assistant).
  1. Download the .tflite file from Colab’s file explorer (look in output_dir).
:wrench: Step 6: Integrate with Home Assistant
Place the .tflite file in your Home Assistant’s
:globe_showing_europe_africa: Next Steps (To-Do List)
Task Status Notes
Translate adversarial phrases :warning: Pending Replace English negatives with French equivalents.
Automate train.py replacement :hammer_and_wrench: In Progress Script to auto-replace the file in Colab.
Multi-language support :light_bulb: Planned Add a dropdown menu to select voice models (French, German, Spanish, etc.).
Thank you for your feedbacks!
to be continued…
Here is the French colab :
Hi, at step 4, there’s no path to openwakeword. Should we execute
“2. Download Data” from Colab before this step?
Yes all steps must be play.
Thank you for this guide in French. I tried to launch the wake word creation process, but it just downloads the .onnx file for my wake word, with an error:
**Traceback (most recent call last):**
**  File "/content/openwakeword/openwakeword/train.py", line 920, in <module>**
**    convert_onnx_to_tflite(os.path.join(config["output_dir"], config["model_name"] + ".onnx"),**
**  File "/content/openwakeword/openwakeword/train.py", line 576, in convert_onnx_to_tflite**
**    from onnx_tf.backend import prepare**
**ModuleNotFoundError: No module named 'onnx_tf'**
**WARNING: All log messages before absl::InitializeLog() is called are written to STDERR**
**E0000 00:00:1765544520.960328   16238 cuda_dnn.cc:8579] Unable to register cuDNN factory: Attempting to register factory for plugin cuDNN when one has already been registered**
**E0000 00:00:1765544520.971439   16238 cuda_blas.cc:1407] Unable to register cuBLAS factory: Attempting to register factory for plugin cuBLAS when one has already been registered**
**W0000 00:00:1765544520.991113   16238 computation_placer.cc:177] computation placer already registered. Please check linkage and avoid linking the same target more than once.**
**W0000 00:00:1765544520.991157   16238 computation_placer.cc:177] computation placer already registered. Please check linkage and avoid linking the same target more than once.**
**W0000 00:00:1765544520.991163   16238 computation_placer.cc:177] computation placer already registered. Please check linkage and avoid linking the same target more than once.**
**W0000 00:00:1765544520.991169   16238 computation_placer.cc:177] computation placer already registered. Please check linkage and avoid linking the same target more than once.**
**  File "/usr/local/bin/onnx2tf", line 5, in <module>**
**    from onnx2tf import main**
**  File "/usr/local/lib/python3.12/dist-packages/onnx2tf/__init__.py", line 1, in <module>**
**    from onnx2tf.onnx2tf import convert, main**
**  File "/usr/local/lib/python3.12/dist-packages/onnx2tf/onnx2tf.py", line 39, in <module>**
**    import onnx_graphsurgeon as gs**
**  File "/usr/local/lib/python3.12/dist-packages/onnx_graphsurgeon/__init__.py", line 1, in <module>**
**    from onnx_graphsurgeon.exporters.onnx_exporter import export_onnx**
**  File "/usr/local/lib/python3.12/dist-packages/onnx_graphsurgeon/exporters/onnx_exporter.py", line 134, in <module>**
**    np.uint16, onnx.helper.float32_to_bfloat16**
**AttributeError: module 'onnx.helper' has no attribute 'float32_to_bfloat16'**
**mv: cannot stat 'my_custom_model/Jarviss_float32.tflite': No such file or directory**
**FileNotFoundError                         Traceback (most recent call last)**
**/tmp/ipython-input-2129544665.py in <cell line: 0>()**
**    106 **
**    107 files.download(f"my_custom_model/{config['model_name']}.onnx")**
**--> 108 files.download(f"my_custom_model/{config['model_name']}.tflite")**
**/usr/local/lib/python3.12/dist-packages/google/colab/files.py in download(filename)**
**    231   if not _os.path.exists(filename):**
**    232     msg = 'Cannot find file: {}'.format(filename)**
**--> 233     raise FileNotFoundError(msg)  # pylint: disable=undefined-variable**
**    234 **
**    235   comm_manager = _IPython.get_ipython().kernel.comm_manager**
**FileNotFoundError: Cannot find file: my_custom_model/Jarviss.tflite**
Do you have any ideas?
Hello everyone,
A big thank you to @Atlantice for their work on the Colab Notebook, which helped me successfully train my own model.
@BadGones0l, I identified the problem: the original version is no longer compatible due to recent TensorFlow updates from Google. To convert an ONNX model to TFLite, make sure to use these exact library versions:
!pip install tensorflow==2.19.0
!pip install onnx2tf
!pip install onnx==1.17.0
!pip install onnxruntime==1.18.1
Building on @Atlantice’s contributions, I’ve written a step-by-step tutorial and updated the Colab notebook. You can access it here: French tutorial on my blog
Note: The article is in French, but the updated Colab notebook is linked inside for direct use.
Thank you very much for your article, I will test this out during the week. :raised_hands:
Thanks for your work, I successfully created my custom Wake Word.
I just have a few optimizations to better detect the wake word (either in my Satellite Wyoming or in the model’s false_activation_penalty).
Hi and thank you for your work on this french tutorial for wakeword!
I tried your colab netbook but I get some errors and the process stops when I run step 2, perhaps it’s another version compatibility problem?
I’ll try again an see if I can debug it.
