GUITION 4" 480x480 ESP32-S3-4848S040 Smart Display with LVGL
Thanks to @clydebarrow for help and suggestions. Here is my work in progress :grinning:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $hvac
              - label:
                  align: bottom_left
                  text_align: center
                  text: "Hvac"
              - obj:
                  width: 160
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - btn:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 70
                        on_click:
                          - lvgl.spinbox.decrement: spinbox_id
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text: "-"
                    - spinbox:
                        align: CENTER
                        text_align: center
                        text_color: 0xB6B6B6
                        bg_opa: transp
                        border_opa: transp
                        width: 80
                        range_from: 18
                        range_to: 28
                        step: 0.5
                        rollover: false
                        digits: 3
                        decimal_places: 1
                        on_value:
                          then:
                            - homeassistant.service:
                                service: climate.set_temperature
                                  temperature: !lambda return x;
                                  entity_id: climate.upstairs
                    - btn:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 70
                        on_click:
                          - lvgl.spinbox.increment: spinbox_id
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
and this is how it’s looks:
But one thing I can’t figured out how to fix is a vertical bar on the right side of the Hvac obj. I want to get rid of this bar , no luck so far
That’s a scroll bar - it means the content is too big to fit in the available space. Adust the height of the objects inside. It might only be a few pixels.
You right , it was a height off the obj. I forgot to calculate a pad (5px top and bottom) when I put height of the second obj. Thank you
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - btn:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text: "-"
                    - spinbox:
                        align: CENTER
                        text_align: center
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        height: 50
                        range_from: 18
                        range_to: 28
                        step: 0.5
                        rollover: false
                        digits: 3
                        decimal_places: 1
                        on_value:
                          then:
                    - btn:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
Thank you everyone for help. This is my final (almost :grinning: ) code :
substitutions:
  friendly_name: "Touch Panel"
  device_description: "Guition ESP32-S3-4848S040 480*480 Smart Screen"
  project_name: "Guition.ESP32_S3_4848S040"
  project_version: "1.0.0"
  lightbulb: "\U000F0335"
  ceiling_light: "\U000F0769"
  lamp: "\U000F06B5"
  floor_lamp: "\U000F08DD"
  string_lights: "\U000F12BA"
  clock: "\U000F0150"
  ceiling_fan: "\U000F1797"
  light_recessed: "\U000F179B"
  blinds_horizontal: "\U000F1A2B"
  blinds_horizontal_closed: "\U000F1A2C"
  curtains_closed: "\U000F1847"
  curtains: "\U000F1846"
  wallsconce: "\U000F091C"
  bed: "\U000F02E3"
  bed_empty: "\U000F08A0"
  thermometer_high: "\U000F10C2"
  humidity: "\U000F058E"
  wallsconce_variant: "\U000F091E"
  kiss: "\U000F0C73"
  hvac: "\U000F0D43"
esphome:
  friendly_name: "${friendly_name}"
  #name_add_mac_suffix: true
  project:
    version: "${project_version}"
  platformio_options:
    board_build.flash_mode: dio
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
      COMPILER_OPTIMIZATION_SIZE: y
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
      CONFIG_SPIRAM_RODATA: y
psram:
  mode: octal
  speed: 80MHz
logger:
api:
  encryption:
    key: "key"
ota:
  password: "ota"
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
web_server:
  port: 80
external_components:
  - source:
      type: git
      url: https://github.com/clydebarrow/esphome
      ref: 82264dc2440981873b8400d613e0cc32d229daa3 #previous commit - wont be needed in the future
    components: [ lvgl ]
time:
  - platform: sntp
    timezone: America/New_York
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
      - script.execute: time_update
    on_time:
      - minutes: '*'
        seconds: 0
        then:
############ AntiBurn ################
script:
  - id: time_update
    then:
      - lvgl.label.update:
          text: !lambda |-
            static char time_buf[17];
            auto now = id(sntp_time).now();
            bool is_pm = now.hour >= 12;
            int hour_12 = now.hour % 12;
            if (hour_12 == 0) {
                hour_12 = 12; // 12 AM/PM should be displayed as 12, not 0
            snprintf(time_buf, sizeof(time_buf), "%2d:%02d%s", hour_12, now.minute, is_pm ? "pm" : "am");
            return time_buf;
###################Temp and Humidity ################
  - platform: homeassistant
    entity_id: sensor.atc_7997_temperature
    on_value:
          text:
            format: "\U000F10C3 %.1f \U000F0504"
            args: [ 'x' ]
    entity_id: sensor.atc_7997_humidity
    on_value:
          text:
            format: "\U000F058E %.1f \U000F03F0"
            args: [ 'x' ]
###############Fan######################
    entity_id: fan.master_fan
    attribute: percentage
    on_value:
      - lvgl.spinbox.update:
          value: !lambda return x;
################HVAC####################
    attribute: temperature
    on_value:
############Cover##############
    entity_id: cover.shades_curtain
    attribute: current_position
    on_value:
      - if:
          condition:
            lambda: |-
              return x == 100;
          then:
            - lvgl.widget.update:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
####Text Sensor####################
text_sensor:
    on_value:
      - if:
          condition:
            lambda: |-
              return ((0 == x.compare(std::string{"opening"})) or (0 == x.compare(std::string{"closing"})));
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_myroom_pos).get_state()' ]
################### Red Lights #######################
switch:
  - platform: lvgl
    widget: lv_button_8
    on_turn_on:
      then:
            text_color: 0xFFFF00
    on_turn_off:
      then:
###################### AntiBurn#####################
################binary_sensors###############
# Lights#
binary_sensor:
    entity_id: light.over_the_bed_lights
    publish_initial_state: true
    on_state:
      then:
        lvgl.widget.update:
          state:
            checked: !lambda return x;
    entity_id: light.mirror_lighs
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.tv_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.irina_s_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.bed_occupancy_sensor_yevgeniy_lights
    on_state:
      then:
        lvgl.widget.update:
          state:
    entity_id: light.my_wall_light
    on_state:
      then:
        lvgl.widget.update:
          state:
#Fan#
    on_state:
      then:
        lvgl.widget.update:
          state:
#Covers#
    entity_id: cover.master_bedroom_all_covers
    on_state:
      then:
        lvgl.widget.update:
          state:
#number:
  # __________________________________________________ backlight timeout
  #- platform: template
    #name: Backlight Timeout
    #optimistic: true
    #id: backlight_timeout
    #unit_of_measurement: "s"
    #initial_value: 30
    #restore_value: true
    #min_value: 10
    #max_value: 90
    #step: 10
    #mode: auto # auto / box / slider
################lvgl Buttons################
lvgl:
  displays:
    - display_id: my_display
  touchscreens:
    - touchscreen_id: my_touchscreen
  on_idle:
    timeout: 120s ###!lambda "return (id(backlight_timeout).state * 1000);" ##fiture use##
    then:
      - logger.log: "LVGL is idle"
      - light.turn_off: backlight
      - lvgl.pause:
##########Pages####################
  top_layer:
    widgets:
      - label:
          text_font: roboto24
          text: "00:00 am"
          align: bottom_mid
          #x: -2
          y: -10
          text_align: right
          text_color: 0xFFFFFF
      - label:
          text_font: roboto24
          text: "-.- %"
          align: bottom_right
          x: -20
          y: -10
          text_align: right
          on_press:
            then:
              - lvgl.page.show: second_page
      - label:
          text_font: roboto24
          text: "-.-°C"
          align: bottom_left
          x: 12
          y: -10
          #text_align: right
          on_press:
            then:
              - lvgl.page.show: main_page
  style_definitions:
    - id: style_line
      line_color: 0x0000FF
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      text_color: 0x333333
      bg_opa: cover
      radius: 4
      pad_all: 2
####Header_Footer##########
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_color: 0x03291F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      border_color: 0x0077b3
      width: 100%
      height: 30
  theme:
    btn:
      text_font: roboto24
      scroll_on_focus: true
      group: general
      radius: 20
      width: 150
      height: 96
      pad_all: 0
      pad_row: 0
      pad_column: 0
      #pad_left: 5px
      #pad_top: 5px
      #pad_bottom: 5px
      #pad_right: 5px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
    obj:
      text_font: roboto24
      group: general
      radius: 20
      width: 150
      height: 100
      pad_left: 5px
      pad_top: 5px
      pad_bottom: 5px
      pad_right: 5px
      shadow_width: 0
      bg_color: 0x0C7B5F
      border_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
  page_wrap: true
  pages:
    - id: main_page
      skip: true
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
      layout: # enable the FLEX layout for the children widgets
        type: FLEX
        flex_flow: ROW_WRAP # the order of the widgets starts top left
        flex_align_cross: CENTER
      widgets:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $light_recessed
              - label:
                  align: bottom_mid
                  text: "Bed Lights"
                  long_mode: dot
            on_short_click:
                  service: light.toggle
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
              - label:
                  align: bottom_mid
                  text: "Mirror Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "TV Lights"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $wallsconce_variant
              - label:
                  align: bottom_mid
                  text: "Irina Light"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_mid
                  text: $bed
              - label:
                  align: bottom_mid
                  text: "Under Bed"
                  long_mode: dot
            on_short_click:
        - obj:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
              - label:
                  align: bottom_mid
                  text: "My Light"
                  long_mode: dot
            on_short_click:
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $hvac
              - label:
                  align: bottom_left
                  text_align: center
                  text: "Hvac"
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - btn:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text_font: montserrat_36
                                text: "-"
                    - spinbox:
                        align: CENTER
                        text_align: CENTER
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        #height: 60
                        range_from: 18
                        range_to: 28
                        step: 0.5
                        rollover: false
                        digits: 3
                        decimal_places: 1
                        on_value:
                          then:
                    - btn:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $kiss
              - label:
                  align: bottom_right
                  text: "Intim"
                  long_mode: dot
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $ceiling_fan
              - label:
                  align: bottom_left
                  text: "Fan"
                 # long_mode: dot
              - obj:
                  width: 160
                  height: 80
                  bg_opa: transp
                  border_opa: transp
                  text_font: light32
                  align: right_mid
                  widgets:
                    - btn:
                        align: left_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.decrement: fan_speed
                        widgets:
                          - label:
                                align: left_mid
                                text_align: left
                                text: "-"
                        on_press:
                          then:
                                service: fan.decrease_speed
                    - spinbox:
                        align: CENTER
                        text_align: CENTER
                        bg_opa: transp
                        border_opa: transp
                        width: 90
                        #height: 60
                        range_from: 0
                        range_to: 100
                        step: 33.3
                        rollover: false
                        digits: 3
                        #decimal_places: 1
                        on_value:
                          then:
                                service: fan.set_percentage
                                  percentage: !lambda return x;
                    - btn:
                        align: right_mid
                        bg_opa: transp
                        width: 50
                        height: 50
                        on_click:
                          - lvgl.spinbox.increment: fan_speed
                        widgets:
                          - label:
                                align: right_mid
                                text_align: right
                                text: "+"
                        on_press:
                          then:
                                service: fan.increase_speed
            on_short_click:
                  service: fan.toggle
        - obj:
            width: 230
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_right
                  text: $curtains
              - label:
                  align: bottom_right
                  text: "Curtains"
                  #long_mode: dot
            on_short_click:
                  service: cover.toggle
############## Second Page#######################
    - id: second_page
      skip: true
      #layout: flex
      #flex_flow: row_WRAP
      width: 100%
      bg_color: 0x000000
      bg_opa: cover
      pad_all: 5
        type: FLEX
      widgets:
############## Covers###################
          - btn:
              x: 10
              y: 30
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text:  "\U000F0143"
              on_press:
                then:
                      service: cover.open
          - btn:
              x: 10
              y: 103
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: STOP
              on_press:
                then:
                      service: cover.stop
          - btn:
              x: 10
              y: 178
              width: 70
              height: 68
              widgets:
                - label:
                    align: CENTER
                    text: "\U000F0140"
              on_press:
                then:
                      service: cover.close
####################HVAC##############################
# Internal outputs
output:
    # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
    # Built in 120v relay
  - id: internal_relay_1
    platform: gpio
    pin: 40
# LIGHTS
light:
  - platform: monochromatic
    output: GPIO38
    restore_mode: ALWAYS_ON
# Graphicsd and Fonts
image:
  - file: https://esphome.io/_images/logo.png
    resize: 200x200
    type: RGB565
  - file: "fonts/wall-sconce-180.svg"
    resize: 20x20
font:
  - file: "gfonts://Roboto"
    bpp: 4
    extras:
      - file: 'fonts/materialdesignicons-webfont.ttf' # http://materialdesignicons.com/cdn/7.4.47/
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
          "\U000F058E",
          "\U000F10C3",
          "\U000F03F0", # mdi-percent
          "\U000F0504", # mdi- celcius
          "\U000F091E",
          "\U000F0143", # mdi-arrow_up
          "\U000F0140", # mdi-arrow_down
    bpp: 4
    glyphs: &mdi-weather-glyphs
      - "\U000F0590" # mdi-weather-cloudy
      - "\U000F0F2F" # mdi-weather-cloudy-alert
      - "\U000F0E6E" # mdi-weather-cloudy-arrow-right
      - "\U000F0591" # mdi-weather-fog
      - "\U000F0592" # mdi-weather-hail
      - "\U000F0F30" # mdi-weather-hazy
      - "\U000F0898" # mdi-weather-hurricane
      - "\U000F0593" # mdi-weather-lightning
      - "\U000F067E" # mdi-weather-lightning-rainy
      - "\U000F0594" # mdi-weather-clear-night
      - "\U000F0F31" # mdi-weather-night-partly-cloudy
      - "\U000F0595" # mdi-weather-partly-cloudy
      - "\U000F0F32" # mdi-weather-partly-lightning
      - "\U000F0F33" # mdi-weather-partly-rainy
      - "\U000F0F34" # mdi-weather-partly-snowy
      - "\U000F0F35" # mdi-weather-partly-snowy-rainy
      - "\U000F0596" # mdi-weather-pouring
      - "\U000F0597" # mdi-weather-rainy
      - "\U000F0598" # mdi-weather-snowy
      - "\U000F0F36" # mdi-weather-snowy-heavy
      - "\U000F067F" # mdi-weather-snowy-rainy
      - "\U000F0599" # mdi-weather-sunny
      - "\U000F0F37" # mdi-weather-sunny-alert
      - "\U000F14E4" # mdi-weather-sunny-off
      - "\U000F059A" # mdi-weather-sunset
      - "\U000F059B" # mdi-weather-sunset-down
      - "\U000F059C" # mdi-weather-sunset-up
      - "\U000F0F38" # mdi-weather-tornado
      - "\U000F059D" # mdi-weather-windy
      - "\U000F059E" # mdi-weather-windy-variant
    bpp: 4
    glyphs: [
      "\U000F0335", # mdi-lightbulb
      "\U000F0769", # mdi-ceiling-light
      "\U000F08DD", # mdi-floor-lamp
      "\U000F12BA", # mdi-string-lights
      "\U000F0150", # mdi-clock
      "\U000F1797", # mdi-ceiling_fan
      "\U000F179B", # mdi-light_recessed
      "\U000F1A2B", # mdi-blinds_horizontal
      "\U000F1A2C", # mdi-blinds_horizontal_closed
      "\U000F1847", # mdi-curtains_closed
      "\U000F1846", # mdi-curtains
      "\U000F091C", # mdi-wallsconce
      "\U000F02E3", # mdi-bed
      "\U000F08A0", # mdi-bed_empty
      "\U000F10C2", # mdi-thermometer_high
      "\U000F058E", # mdi-humidity
      "\U000F091E", # mdi-wallsconce_variant
      "\U000F0C73", # mdi-kiss
      "\U000F0D43", # mdi- hvac
    bpp: 4
# Touchscreen gt911 i2c
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
          format: Touch at (%d, %d)
          args: [touch.x, touch.y]
    - lambda: |-
          ESP_LOGI("cal", "x=%d, y=%d, x_raw=%d, y_raw=%0d",
              touch.x,
              touch.y,
              touch.x_raw,
              touch.y_raw
  on_release:
    then:
      - if:
          condition: lvgl.is_paused
          then:
            - logger.log: "LVGL resuming"
            - lvgl.resume:
            - lvgl.widget.redraw:
            - light.turn_on: backlight
# Display st7701s spi
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
display:
  - platform: st7701s
    update_interval: never
    auto_clear_enabled: True
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    invert_colors: false
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
      - [0xFF, 0x77, 0x01, 0x00, 0x00, 0x10] # CMD2_BKSEL_BK0
      - [0xCD, 0x00] # disable MDT flag
    pclk_frequency: 12MHz
    pclk_inverted: false
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
2 things I would like to add:
  1. AntiBurn ( for some reason it’s give me an error)
  2. Some how I want to add white color by default when I turn on My Light( it’s multi color light and when I change color, next time I turn on I want color to be white, not the color I left on when I turn off)
Hey! How did you adjust the buttons to not be below the footer? Thank you!
Use a footer and Header styling
  top_layer:
    widgets:
      - label:
          text_font: roboto24
          text: "00:00 am"
          align: bottom_mid
          #x: -2
          y: -10
          text_align: right
      - label:
          text_font: roboto24
          text: "-.- %"
          align: bottom_right
          x: -20
          y: -10
          text_align: right
          on_press:
            then:
      - label:
          text_font: roboto24
          text: "-.-°C"
          align: bottom_left
          x: 12
          y: -10
          #text_align: right
          on_press:
            then:
  style_definitions:
    - id: style_line
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      bg_opa: cover
      radius: 4
      pad_all: 2
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      width: 100%
      height: 30
I’m getting the feeling with the coding of the screen.
but I run into a problem. I use buttons on the screen to make turn on or off a switch in home assistant. And I want the background of the button change to the state of the entity.
in the code below on line 1151 there is a ā€œbg_color:ā€ line if I put a color in the button changes color. so far so good but it needs to be variable.
substitutions:
  friendly_name: guition-tuin
  lamp: "\U000F06B5"
  clock: "\U000F0150"
  bed: "\U000F02E3"
  pool: "\U000F0606"
  home: "\U000F07D0"
  music: "\U000F0387"
  volume_down: "\U000F075E"
  volume_off: "\U000F0581"
  volume_up:  "\U000F075D"
  cover_up:  "\U000F075D"
  cover_down:  "\U000F075D"
  fountain:  "\U000F096B" # mdi-fountain
esphome:
  project:
  platformio_options:
esp32:
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
psram:
  mode: octal
  speed: 80MHz
logger:
api:
  encryption:
    key: "OF+IxRDrZuVHUxdWdgo8oTUtspPhX49xvbRTQmkWBKQ="
ota:
  - platform: esphome
    password: "f3d9af347d4086fb1911340933aff60a"
wifi:
web_server:
  port: 80
 - source: github://clydebarrow/esphome@lvgl_original
   refresh: 10min
time:
  - platform: sntp
    timezone: Europe/Amsterdam
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
    on_time:
      - minutes: '*'
        seconds: 0
        then:
script:
  - id: time_update
    then:
          text: !lambda |-
            if (hour_12 == 0) {
            snprintf(time_buf, sizeof(time_buf), "%2d:%02d%s", now.hour, now.minute, is_pm ? "" : "");
            return time_buf;
################### Home-Assistant sensors ################
    entity_id: sensor.achtertuin_temperatuur_temperature
    on_value:
          text:
            format: "\U000F10C3 %.1f°C"
            args: [ 'x' ]
    entity_id: sensor.achtertuin_temperatuur_humidity
    on_value:
          text:
            format: "\U000F058E %.1f%%"
            args: [ 'x' ]
    entity_id: sensor.bloembak_meisje_moisture
    on_value:
          text:
            args: [ 'x' ]
    entity_id: sensor.bloembak_huis_moisture
    on_value:
          text:
            args: [ 'x' ]
    entity_id: sensor.flower_care_moisture
    on_value:
          text:
            args: [ 'x' ]
    entity_id: cover.screen_woonkamer
    on_value:
      - if:
          condition:
            lambda: |-
              return x == 100;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
    entity_id: cover.zonnescherm
    on_value:
      - if:
          condition:
            lambda: |-
              return x == 0;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
      - if:
          condition:
            lambda: |-
              return x == 100;
          then:
                text_opa: 60%
          else:
                text_opa: 100%
#  - platform: homeassistant
#    id: time_ha
#    entity_id: sensor.achtertuin_temperatuur_humidity
#    on_value:
#      - lvgl.label.update:
#          id: display_time_ha
  # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
  - platform: wifi_signal
    update_interval: 60s
################TEXT Sensors################
text_sensor:
    on_value:
      - if:
          condition:
            lambda: |-
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_screen_pos).get_state()' ]
    on_value:
      - if:
          condition:
            lambda: |-
          then:
                text: "STOP"
          else:
                text:
                  format: "%.0f%%"
                  args: [ 'id(cover_zonnescherm_pos).get_state()' ]
    entity_id: input_boolean.test
    on_value:
      - if:
          condition:
           lambda: |-
              return x == 1;
          then:
                bg_color:  0x0C7B5F
          else:
                bg_color:  0xCC5E14
lvgl:
  displays:
  touchscreens:
  on_idle:
    - timeout: 90s
      then:
        - logger.log: idle timeout
        - lvgl.pause:
        - light.turn_off:
            transition_length: 5s
  style_definitions:
    - id: style_line
      line_width: 8
      line_rounded: true
    - id: date_style
      text_font: roboto24
      align: center
      bg_opa: cover
      radius: 4
      pad_all: 2
    - id: header_footer
      bg_color: 0x0C7B5F
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      width: 100%
      height: 40
  theme:
    btn:
      text_font: roboto24
      group: general
      radius: 25
      width: 150
      height: 97
      pad_left: 10px
      pad_top: 10px
      pad_bottom: 10px
      pad_right: 10px
      shadow_width: 0
      bg_color: 0x0C7B5F
      checked:
        bg_color: 0xCC5E14
#                      Waterornamenten
    - id: page_waterornamenten
      bg_color: 0x000000
      widgets:
        - label:
            text_font: roboto50
            text_color: 0xFFFAFF
            x: 0
            y: 0
            width: 480
            height: 68
            text: "Waterornamenten"
            text_align: CENTER
        - btn:
            x: 20
            y: 140
            width: 200
            height: 200
            bg_color: btn_water_meisje
            widgets:
              - label:
                  text_font: roboto100
                  align: CENTER
                  text: $fountain
              - label:
                  align: bottom_mid
                  text: "Meisje"
            on_click:
                  service: homeassistant.toggle
        - btn:
            x: 260
            y: 140
            width: 200
            height: 200
            widgets:
              - label:
                  align: CENTER
                  text: $fountain
              - label:
                  align: bottom_mid
                  text: "Waterbakjes"
            on_click:
        - btn:
            x: 206
            y: 395
            width: 68
            height: 68
            widgets:
              - label:
                  text_font: light32
                  align: center
                  text: $home
            on_press:
              then:
With the code above the ESP-Home compiler trows the error below.
INFO ESPHome 2024.7.1
INFO Reading configuration /config/esphome/guition--tuin.yaml...
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
Failed config
text_sensor.homeassistant: [source /config/esphome/guition--tuin.yaml:286]
  on_value:
    - then:
        - if:
            condition:
              lambda: !lambda |-
                return x == 1;
            then:
                  Couldn't find ID 'btn_water_meisje'. Please check you have defined an ID with that name in your configuration. These IDs look similar: "btn_meisje", "btn_waterbakjes", "btn_meisje_icon".
                  bg_color: lv_color_hex(0xC7B5F)
            else:
                  bg_color: lv_color_hex(0xCC5E14)
  disabled_by_default: False
Who can/wants to point me to the error?
I removed a lot of unintresting code (pages due to the 32000 limit everything relevant should be there
When trying to compile the following
esphome:
  friendly_name: PoolToy
  platformio_options:
  on_boot:
    - delay: 5s
    - lvgl.widget.hide: boot_screen
# Enable logging
logger:
  level: DEBUG
# Enable Home Assistant API
api:
  encryption:
    key: "jmCgYDFZCCMHuXIolnsws4oYXRb4keFvCwkx85oxHu0="
  on_client_connected:
    - if:
        condition:
          lambda: 'return (0 == client_info.find("Home Assistant "));'
        then:
          - lvgl.widget.show: lbl_hastatus
  on_client_disconnected:
    - if:
        condition:
        then:
          - lvgl.widget.hide: lbl_hastatus
ota:
  - platform: esphome
    password: "d34814fd15e289a7d66c34829fffe162"
wifi:
  use_address: pooltoy.iot
  ap:
    ssid: "Pooltoy Fallback Hotspot"
    password: "senzafili"
captive_portal:
substitutions:
  left:          "\U000F12BA"
  right:         "\U000F12BB"
  home:          "\U000F12BC"
  connection:    "\U000F12BD"
# ESPHOME PLATFORM SETTINGS
#esphome:
#  name: 480screen
#  friendly_name: 480screen
#  platformio_options:
#    board_build.flash_mode: dio
# ESP MCU SETTINGS for
# Guition ESP32-S3-4848S040
esp32:
  variant: esp32s3
  flash_size: 16MB
  framework:
    type: esp-idf
    sdkconfig_options:
psram:
  mode: octal
  speed: 80MHz
web_server:
  port: 80
  - source: github://pr#6363
    refresh: 10min
    components: [lvgl]
time:
  - platform: sntp
    servers:
     - 0.pool.ntp.org
     - 1.pool.ntp.org
     - 2.pool.ntp.org
    on_time_sync:
    on_time:
      - minutes: '*'
        seconds: 0
        then:
script:
  - id: time_update
    then:
          text: !lambda |-
            if (hour_12 == 0) {
            snprintf(time_buf, sizeof(time_buf), "%02d:%02d%s", hour_12, now.minute, is_pm ? "pm" : "am");
            return time_buf;
# Buttons
switch:
  - platform: lvgl
    widget: lv_button_1
    on_turn_on:
      then:
            service: light.turn_on
              entity_id: light.cespuglio_ingresso
    on_turn_off:
      then:
            service: light.turn_off
  - platform: lvgl
    widget: lv_button_2
    on_turn_on:
      then:
    on_turn_off:
      then:
# lvgl Buttons
lvgl:
#  on_idle:
#    timeout: 90s
#    then:
#      - logger.log: "LVGL is idle"
#      - light.turn_off: backlight
#      - lvgl.pause:
  theme:
#    label:
#      text_font: roboto24 # set all your labels to use your custom defined font
    btn:
      width: 120
      height: 120
      bg_color: 0xFFFFFF #0x2F8CD8
      bg_grad_color: 0xFFFFFF #0x005782
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 1
      text_color: 0x000000 #0xFFFFFF
      pressed: # set some btn colors to be different in pressed state
        bg_color: 0x006699
        bg_grad_color: 0x00334d
      checked: # set some btn colors to be different in checked state
        bg_color: 0x1d5f96
        bg_grad_color: 0x03324A
        text_color: 0xfff300
    btnmatrix:
      bg_opa: TRANSP
      border_width: 0
      pad_all: 0
      items: # set all your btnmatrix buttons to use your custom defined styles and font
        bg_color: 0x2F8CD8
        bg_grad_color: 0x005782
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
        pressed:
          bg_color: 0x006699
        checked:
          bg_color: 0x1d5f96
          text_color: 0x005580
    switch:
      bg_color: 0xC0C0C0
      bg_grad_color: 0xb0b0b0
      bg_grad_dir: VER
      bg_opa: COVER
      checked:
        bg_color: 0x1d5f96
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0xFFFFFF
        bg_grad_color: 0xC0C0C0
        bg_grad_dir: VER
        bg_opa: COVER
    slider:
      border_width: 1
      border_opa: 15%
      bg_color: 0xcccaca
      bg_opa: 15%
      indicator:
        bg_color: 0x1d5f96
        bg_grad_dir: VER
        bg_opa: COVER
      knob:
        bg_color: 0x2F8CD8
        bg_grad_dir: VER
        bg_opa: COVER
        border_width: 1
  style_definitions:
    - id: header_footer
#      text_font: light32
      bg_color: 0x2F8CD8
      bg_grad_dir: VER
      bg_opa: COVER
      border_width: 0
      radius: 0
      pad_all: 0
      pad_row: 0
      pad_column: 0
      width: 100%
      height: 30
  displays:
  touchscreens:
#  style_definitions:
#    - id: style_line
#      line_color: 0x0000FF
#      line_rounded: true
##      line_width: 8
#    - id: date_style
#      align: center
#      text_color: 0x333333
#      bg_opa: cover
#      radius: 4
#      pad_all: 2
#  theme:
#    btn:
#      scroll_on_focus: true
#      radius: 25
#      group: general
#      width: 150
#      height: 109
#      pad_left: 10px
#      pad_top: 10px
#      pad_bottom: 10px
#      pad_right: 10px
#      shadow_width: 0
#      bg_color: 0x313131
#      text_color: 0xB6B6B6
#      checked:
#        bg_color: 0xCC5E14
  top_layer:
    widgets:
      - btnmatrix:
          align: bottom_mid
          styles: header_footer
          pad_all: 0
          outline_width: 0
          items:
          rows:
            - buttons:
              - id: page_prev
                text: "\uF053"
                on_press:
                  then:
                    lvgl.page.previous:
              - id: page_home
                text: "\uF015"
                on_press:
                  then:
                    lvgl.page.show: stato_piscina
              - id: page_next
                text: "\uF054"
                on_press:
                  then:
                    lvgl.page.next:
      - label:
          text: "\uF1EB"
          hidden: true
          align: top_right
          text_align: right
      - obj:
          x: 0
          y: 0
          width: 100%
          height: 100%
          bg_color: 0xffffff
          bg_opa: COVER
          radius: 0
          pad_all: 0
          border_width: 0
          widgets:
            - img:
                align: CENTER
                src: boot_logo
            - spinner:
                align: CENTER
                y: 150
                height: 50
                width: 50
                spin_time: 1s
                arc_length: 60deg
                arc_width: 8
                indicator:
                  arc_color: 0x18bcf2
                  arc_width: 8
          on_press:
  page_wrap: true
  pages:
    - id: stato_piscina
      widgets:
        - obj:
            align: TOP_MID
            widgets:
            - label:
                text: "Stato"
                align: CENTER
                text_align: CENTER
        - obj:
            align: CENTER
            width: 480
            height: 420
            text_font: montserrat_26
            pad_all: 0
            pad_column: 0
            scrollable: OFF
            layout:
              type: GRID
              grid_rows: [ FR(52), FR(52),FR(52),FR(52),FR(52),FR(52),FR(52),FR(52)]
              grid_columns: [FR(60), FR(420)]
            widgets:
              #ROW 1
              - img:
                  src: temperatura_esterna
                  grid_cell_row_pos: 0
                  grid_cell_column_pos: 0
              - label:
                  text: "Temperatura Ambiente"
                  text_align: RIGHT
                  grid_cell_column_pos: 1
            #ROW 2
              - img:
                  src: temperatura_acqua
                  grid_cell_row_pos: 1
              - label:
                  text: "Temperatura Acqua"
                  text_align: RIGHT
            # ROW 3
              - img:
                  src: raggi_uv
                  grid_cell_row_pos: 2
              - obj:
                  width: 420
                  height: 52
                  scrollable: OFF
                  radius: 0
                  pad_all: 0
                  bg_opa: cover
                  widgets:
                    - obj:
                        x: 0
                        width: 84
                        height: 48
                        radius: 0
                    - obj:
                        x: 84
                        width: 84
                        height: 48
                        radius: 0
                    - obj:
                        x: 168
                        width: 84
                        height: 48
                        radius: 0
                    - obj:
                        x: 252
                        width: 84
                        height: 48
                        radius: 0
                    - obj:
                        x: 336
                        width: 84
                        height: 48
                        radius: 0
            # ROW 4
              - img:
                  src: ph
                  grid_cell_row_pos: 3
              - bar:
                  pad_top: 5
                  pad_bottom: 5
                  align: CENTER
                  value: 75
                  min_value: 1
                  max_value: 100
                  width: 420
                  height: 28
                  radius: 0
              - img:
                  src: orp
                  grid_cell_row_pos: 4
              - label:
                  text: "orp"
                  text_align: RIGHT
              - img:
                  src: salinita
                  grid_cell_row_pos: 5
              - label:
                  text: "salinita"
                  text_align: RIGHT
              - img:
                  src: livello_tanica
                  grid_cell_row_pos: 6
              - label:
                  text: "Livello Tanica"
                  text_align: RIGHT
              - img:
                  src: manutenzione
                  grid_cell_row_pos: 7
              - label:
                  text: "Ultimo Controlavaggio"
                  text_align: RIGHT
    - id: luci_e_interruttori
      layout:
        type: flex
        flex_flow: ROW_WRAP
        flex_align_main: SPACE_EVENLY
        flex_align_cross: SPACE_EVENLY
      widgets:
        - obj:
            align: TOP_MID
            widgets:
              - label:
                  text: "Luci e Interruttori"
                  align: CENTER
                  text_align: CENTER
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Cespuglio Ingresso"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $string_lights
              - label:
                  align: bottom_left
                  text: "Outdoor"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              #- label:
              #    align: top_left
              #    text: $floor_lamp
              #    id: lv_button_3_icon
              #- label:
              #    align: bottom_left
              #    text: "Living Room"
              #    long_mode: dot
              - img:
                  align: CENTER
                  src: wink
              - label:
                  align: bottom_left
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Accent"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Bed Room"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "00:00am"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Fan"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Timer"
                  long_mode: dot
        - btn:
            checkable: true
            widgets:
              - label:
                  text_font: light32
                  align: top_left
                  text: $lightbulb
              - label:
                  align: bottom_left
                  text: "Lamp"
                  long_mode: dot
    - id: musica
      layout:
        type: flex
        flex_flow: COLUMN_WRAP
      widgets:
        - obj:
            align: TOP_MID
            widgets:
              - label:
                  text: "Musica"
                  align: CENTER
                  text_align: CENTER
              - bar:
                  x: 10
                  y: 100
                  align: CENTER
                  width: 480
                  height: 100
                  value: 75
                  min_value: 1
                  max_value: 100
    - id: sicurezza
      layout:
        type: flex
      widgets:
        - obj:
            align: TOP_MID
            widgets:
              - label:
                  text: "Sicurezza"
                  align: CENTER
                  text_align: CENTER
        - img:
            align: CENTER
            src: wink
# Internal outputs
output:
    # Backlight LED
  - platform: ledc
    pin: GPIO38
    frequency: 100Hz
    # Built in 240v relay
    platform: gpio
    pin: 40
image:
    resize: 480x480
    type: RGB565
#  - file: "images/001.png"
#    id: wallsconce_180
#    resize: 20x20
 # - file: "images/carbon.jpg"
#    id: wall_carbon
#    resize: 480x480
#    type: RGB565
# sensori
  - file: "images/pooltoy/pooltoy.png"
    resize: 480x480
    type: RGB565
  - file: "images/pooltoy/noun-grounding-rod-6993401.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-ph-5797721.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-soil-salinity-6490657.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-temperatureexternal-6844994.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-temperature-6970346.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-uv-protection-6043887.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-beaker-7710.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-orp.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/wink.png"
    resize: 52x52
    type: RGB565
# Luci e Interruttori
  - file: "images/pooltoy/noun-grass-5105978.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-olive-tree-6942066.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-lamp-4897109.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-maintenance-6731622.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-pool-pump-6952149.jpg"
    resize: 52x52
    type: RGB565
  - file: "images/pooltoy/noun-pool-6935336.jpg"
    resize: 52x52
    type: RGB565
font:
  - file: "fonts/materialdesignicons-webfont.ttf"
    bpp: 4
    glyphs: [
      "\U000F0594", # clear-night
      "\U000F0590", # cloudy
      "\U000F0F2F", # exceptional
      "\U000F0591", # fog
      "\U000F0592", # hail
      "\U000F0593", # lightning
      "\U000F067E", # lightning-rainy
      "\U000F0595", # partlycloudy
      "\U000F0596", # pouring
      "\U000F0597", # rainy
      "\U000F0598", # snowy
      "\U000F067F", # snowy-rainy
      "\U000F0599", # sunny
      "\U000F059D", # windy
      "\U000F059E", # windy-variant
      "\U000F14E4", # sunny-off
    bpp: 4
    extras:
        glyphs: [
          "\U000F004B",
          "\U0000f0ed",
          "\U000F006E",
          "\U000F012C",
          "\U000F179B",
          "\U000F0748",
          "\U000F1A1B",
          "\U000F02DC",
          "\U000F0A02",
          "\U000F035F",
          "\U000F0156",
          "\U000F0C5F",
          "\U000f0084",
          "\U000f0091",
    bpp: 4
    bpp: 4
    glyphs: [
      "\U000F12BB", # mdi-string-lights
      "\U000F12BC", # mdi-string-lights
      "\U000F12BD", # mdi-string-lights
      "\U000F12BE", # mdi-string-lights
    bpp: 4
i2c:
  - id: bus_a
    sda: GPIO19
    scl: GPIO45
    #frequency: 100kHz
touchscreen:
  platform: gt911
  transform:
    mirror_x: false
    mirror_y: false
  display: my_display
  on_touch:
    - logger.log:
    - lambda: |-
          touch.x,
          touch.y,
          touch.x_raw,
          touch.y_raw
  on_release:
      - if:
          then:
            - lvgl.resume:
spi:
  - id: lcd_spi
    clk_pin: GPIO48
    mosi_pin: GPIO47
display:
  - platform: st7701s
    data_rate: 2MHz
    spi_mode: MODE3
    color_order: RGB
    dimensions:
      width: 480
      height: 480
    transform:
      mirror_x: false
      mirror_y: false
    cs_pin: 39
      # reset not defined
    de_pin: 18
    hsync_pin: 16
    vsync_pin: 17
    pclk_pin: 21
    init_sequence:
      - 1
    data_pins:
      red:
        - 11         # R1
        - 12         # R2
        - 13         # R3
        - 14         # R4
        - 0          # R5
      green:
        - 8          # G0
        - 20         # G1
        - 3          # G2
        - 46         # G3
        - 9          # G4
        - 10         # G5
      blue:
        - 4          # B1
        - 5          # B2
        - 6          # B3
        - 7          # B4
        - 15         # B5
binary_sensor:
    on_state:
      then:
        lvgl.widget.update:
          state:
text:
  - platform: lvgl
    widget: lbl_temperatura_acqua
    mode: text
  - platform: lvgl
    mode: text
# LIGHTS
light:
    output: GPIO38
#  - platform: binary
#    output: internal_relay_1
#    name: Internal Light
#    id: internal_light
#    on_turn_on:
#      then:
#        - lvgl.widget.update:
#            id: lv_button_1_icon
#            text_color: 0xFFFF00
#            id: lv_button_1
#            state:
#              checked: true
#    on_turn_off:
#      then:
#            id: lv_button_1
#            state:
#              checked: false
If I try to add a
bg_color:
option at the page stato_piscina - ROW 3
either at parent object or at children (as below)
             - obj:
                  width: 420
                  height: 52
                  scrollable: OFF
                  radius: 0
                  pad_all: 0
                  bg_opa: cover
                  widgets:
                    - obj:
                        x: 0
---                    bg_color: #000000
                        width: 84```
I get the following error
Couldn't find any component that can be used for 'Color'. Are you missing a hub declaration?.
No quick fix available
wrong color format
bg_color: #000000
Does this error message not give you some clue?
Thank you for your reply,
unfortunaly not. i have checked it and its declared like other stats. (zonnescherm/screen)
has anybody been able to successfully use the action lvgl.slider.update ? It just won’t update between esphome and HA. If I change the widget to arc and use lvgl.arc.update, it works without any other changes. So I don’t think my code is faulty.
    entity_id: light.fan_living_room_light
    attribute: brightness
    on_value:
      - lvgl.slider.update:
        - obj:
            checkable: true
            height: 210
            widgets:
            - slider:
                #width: 30
                #height: 150
                min_value: 0
                max_value: 255
                on_release:
                        brightness: !lambda return int(x);
There is either a language or a comprehension barrier here. Let me break it down very simply;
Your code:
                bg_color:  0x0C7B5F
is attempting to change the state of a label, and it’s specified that that label should have an id of btn_water_meisje. So somewhere in your config there should be a label defined, like this:
    - label:
The error message is Couldn't find ID 'btn_water_meisje' so it’s saying there is nothing in the yaml declared with that id (label or otherwise.)
So let’s look at the rest of the config. First search for all the labels - look for the pattern - label:. There are 6 in all. One doesn’t have id defined at all, the others are:
              - label:
                  align: CENTER
                  text: $fountain
              - label:
                  align: bottom_mid
                  text: "Meisje"
              - label:
                  align: CENTER
                  text: $fountain
              - label:
                  align: bottom_mid
                  text: "Waterbakjes"
              - label:
                  text_font: light32
                  align: center
                  text: $home
Look carefully at the id: key for each of those - do any of them have the id btn_water_meisje? I would say no, even though I don’t understand Nederlands.
So I agree with the yaml parser - there is no label defined with that ID.
So when you say
you must have been looking at something completely different, or ā€œitā€ means something else entirely. I have no idea, since you didn’t say what ā€œitā€ was and I can only go on the yaml you provided. Perhaps the ā€œuninterestingā€ stuff you omitted is important? Either way, there is no label defined with that ID, because that’s what the error message says. No amount of denial changes that.
If you think you have defined such a label, show us the code that you think does so and somebody will be able to point out your error.
Fixed recently, make sure you are using the latest version of the PR.
Hello! I have a few questions about LVGL (ESPHome) and this display in particular. Could you spare a little time and answer a few questions?
Questions:
  1. How do I change the background in the switch widget when it is on?
indicator:
   bg_color: 0xFF0000
not working
2) What should I write in external_components to always get the latest version?
3) I get beautiful things in LVGL, but there are problems with the gradient, as well as the alpha channel. If I remove the background from the picture, aliasing appears. I have to make weather icons using glyphs, which is very inconvenient. As far as I understand, in both cases the problem is in RGB565? Can this display output RGB888? If so, is there an implementation of this functionality in LVGL 8.4 or do I need version 9?
4) I saw the LVGL-9 branch on GitHub. Is this version usable and is there documentation for it?
Thank you very much in advance for answering my questions.
Best regards, Alex
        - switch:
            indicator:
              checked:
                bg_color: 0xFF0000
    refresh: 10min
    components: [ lvgl]
Yes, this is because RGB565 does not have an alpha channel. There is support in LVGL for RGB565A images but this is not yet supported in ESPHome.
It’s not complete and would not help with the transparency issue in any case.
- switch:
    indicator:
      checked:
      bg_color: 0xFF0000
It works)) I tried the ā€œindicatorā€ and ā€œcheckcedā€ separately, but didn’t think of doing it together (this should be corrected in the documentation). Thank’s a lot))
I’m working on a thermostat, it works very well, but I would like the ā€œtarget temperatureā€ to be displayed as a dot, like in home assistant. Is this possible? And is it possible to superimpose another ā€œarcā€ from this dot, like in Home Assistant?
But it should be like in home Assistant. Is it possible?
And another question, why in the ā€œgridā€ mode there are indents on the right and down? Small, about 2 pixels, how to remove them?
P.S. Once again, I would like to express my deep gratitude to you for your work.
Yes, all that’s possible, probably with multiple superimposed arc widgets. But I’m a programmer not a designer so can’t really help much more than that.
Without seeing it, at a guess I would say they are scroll bars, due to the content being just a bit too big for the container.
