I had the same issue for the H1M & H1 Pro in Z2MQTT and the fix for this was to update the firmware on my coordinator.
You might have to do the same to start seeing those values, unless there’s an issue with the quirks you’re currently using.
EDIT: Found this PR linked to this issue. Seems the fixes were merged in recently.
Are you on the latest (2024.2.x) HA version?
Don’t upgrade your coordinator firmware just yet - I don’t think that will help. I posted that advice before I found out that this is an issue that is being worked on in ZHA.
Ask in the github issue above whether the fix was released. It could be that the fix was merged in but didn’t make it in time for the HA release.
If it was released, you might need to force update the quirks your devices are using.
Not 100% sure how that’s done in ZHA. You’ll probably either have to reconfigure your devices or remove them and re-add them.
