H2 change the temperature of a Fritz 302 with a script
I am currently experimenting with the Fritz digital thermostat 302. The Home Assistant integration works well but I wonder how I can control the temperature through a script?
It is possible to change the temperature in the front end with the round gauge.
But on the automation side, I can only change the presets or turn the heater on and off. Surely, there must be a way to change the temp, as it is possible manually in the front end. Any ideas?
