2020-07-04 10:17:54 ERROR (MainThread) [homeassistant.components.mobile_app.notify] Requested entity was not found.
I had the situation that my iOS notify stopped working. Then I started the iOS app and it works again. Then I put the app into the background and it still works. Last was I closed the app and it also works. It seems like if the app is not running for a longer time something is happening in the background that kill’s the communication. As soon as the app runs again it briefly works for a while.
I’m a bit stuck on what I should do with the following warning regarding the Logitech Harmony remote;
XMPP is not enabled, using web sockets however this might not work with future Harmony firmware updates, please enable XMPP
If I go to harmony app to attempt to enable it reports;
WARNING! By enabling XMPP connection you are disabling a critical security feature required to safeguard you against vulnerabilities. This connection may create an unsecured local access point vulnerable to be hacked. We recommend all users disable this connection.
I’m not exactly sure what the potential security issue I’ll be opening than leaving HA currently to use WebSockets and if they later remove support to WebSockets switch over then?
There is a chance that the issue in the 2020.3 with critical notifications has caused some push tokens to become invalid. If you go to App Configuration>Notifications and reset the token then restart Home Assistant, this may clear the issue.
My notification aren’t working either anymore. I can’t seem to get a new push id. I recently switched to Telegram bot. It’s as good and allows me to send photo’s too. The companion app does it too, but it can only be viewed when on your local network. Now I see it all the time. So, I am really happy having switched.
